Hi guys thinking of getting turbo timer and air filter for my R34, what do ya think suit my GTT(stock)? For air filter, currently using HKS, havent really try out anything else, so kinda confused
Money doesnt really matter, been saving for this :D ...
I narrowed down my turbo timer choices to
HKS - Turbo timer type 0 and type 1
Blitz - Dual Turbo Timer - DCIV
Greddy - Full Auto Timer
and for air filter
Blitz sonic power
Blitz SUS
HKS super power
Apexi power
All of them must have their own unique features rite?
Have ur say...
Cheers
https://www.sau.com.au/forums/topic/213210-buying-new-air-filter/
Stick with your HKS air filter, I got one and it works fine.
I have a Blitz copy turbo timer and it probley does the same thing as the real Blitz one maybe minus a feature. As long as its reliable and allows your car to idle at the set time and able to lock your car while it idling and switch off and keep the car locked up.
Blitz SUS, looks the best if you've got a polished engine bay i reckon.
The choice of filter you buy can make a difference to the way your engine bay looks, which then would fall under the heading of cosmetics and styling...............
http://www.3aracing.com.au/HTML%20Folder/0...erShootOut.html
Outright Winner of the
Ultimate Air Filter Shoot Out
1st in Flow - A huge 601.2 CFM!
3A Racing out - gunned Apexi, K&N, HKS, Trust & AEM
$40 filter + $20 adapter ~~
Contact http://www.3aracing.com.au/ for price.
I have the Apexi pen style timer, it's good and not expensive. They have them on Nengun.com so check it out.
I had an HKS pod filter, was good, but my tuner chucked it and put on the Apexi filter. Reasoning is the HKS pod (or any foam filter) needs to be oiled. The oil gets into the intake system and fouls the AFM element, meaning the meter will need to be cleaned more often.
So don't get an 'oiled' filter.
+ 1 for 3a racing pod
i second this..... they are a cheepo but flow and filtration is much better than the over priced jap "brand name filters" i dont have one but the tests have prooved that these are tops
do a search, a while back in a thread bout filters i posted up a huge comparison of common filters 11 or so with flow rates and filtration rates
i have a Blitz SUS... sounds absolutely awesome, seriously...
does the job too i guess :/
in regards to turbo timer, what do you want it to do...?
keep your car running for a tiny while to let the turbo and engine cool down right?
all timers do the same thing in theory, me and m brother both have invisible ones interfaced with the alarm...
key out, engine still running... one/two minute(s) later engine off... they all do the same job mate, which one looks nicer in the car? :banana:
my2c
Andrew
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
