Hey guys,
I recently bought and got installed an apparently "good condition" second hand hypergear tr43 turbo... which when I bought it had a chip on the corner of one of the fins probably about half the size of this zero: -0-
When I asked the mechanic if this was ok he said it was fine.... I was skeptical... how can something that has to spin at such a speed and maintain a constant high output while attempting to stay in the exact same spot be ok when it doesn't have perfect balance? none the less I went through with it.....
I am meant to have a tune in a week by dr. drift.. who I hope will fix the slow spooling issue... because I am only getting full boost by about 4,800-5,000 rpm... an issue I am not sure if being caused by the chip....
I also am hearing a slight whistling sound when I drive... but that could be my dump pipe and the back of the turbo not being sealed 100%?
I saw hypergear (Tao) who said he doesn't think it is a smart idea to run the turbo if it is off balance at all because at high rpm it will wiggle a little and then start destroying seals etc etc...
I have spoken to the mechanics again.. who said they would give me the money back for the turbo... but I will have to be charged labour if they take it off again.. I am thinking i may just do it myself and replace it with a brand new tr43 myself...(because it will fit identical so no customizations that I will have to worry about)
I need some more opinions desperately! DO YOU THINK THE TURBO SHOULD BE REPLACED? OR WILL IT BE OK AND RUNNING CORRECTLY? tell me you honest opinions because right now I am so confused what to do...
Much appreciated,
Adam
https://www.sau.com.au/forums/topic/213258-help-small-chip-in-turbo-wheel/
Personally i wouldnt do it, in my opinion it would be slightly unbalanced and over time (who knows how long) could get worse and potential throw the balance of the wheel off and make it start hitting the housing.
Edited by PM-R33
you have to ask yourself, why is it chipped, what caused it? did something get sucked into it and chip it?
where did it end up? what the hell has enterd the turbo? and what might have passed through it?
basically, id be taking it off yourself, returning it to whoever sold it to you.
If it lets go your motor might get a mouthfull of metal
Edited by Mr. Untouchable
Thanks for the advice guys, really does help me rule out what to do....
this is the update from today and me spending about $50 on the phone bill to the mechanics and Hypergear:
Mechanics: The turbo they showed me they would put in my car (with the chip) "apparently" IS NOT the one that is currently in the car but the exact same model...
Hypergear: The turbo currently on my car has "apparently" got the same model number "0000029" as the demo one they gave the mechanics a number of years ago.. and the turbo that is on my car was also made a number of years ago...
SO NOW THE TEST... I worked out=
I said to the mechanics:"are you 100% positive this is not the turbo you showed me with the chip?" they looked me right in the eye and said: "no....take off the intake pipe and check it yourself"
so tommorow I will take off the intake pipe to the turbo... I will check the fins... if any single one is chipped I am going to give hell to the mechanics for lying right to my face!
if it is fine then hypergear should not make accusations ...
We will see..
Adam
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
