I just did the r34gtt front brake conversion this morning on my m35 axis. As others have said, pretty much direct bolt on. Just had to remove the olive/restrictor from the gtt calipers and the dust shield met Mr hammer which worked well. I managed to get the required clearance without trimming it. The axis rims fit back on without clearance issues which is a bonus. Just got to bleed the brakes after lunch and go for a drive. All in all, very straightforward upgrade.
Is the internal diameter of the m35 line connector the same as this 'restrictor'. Thats why i kept mine in
I believe the restrictor needs to be removed otherwise the banjo bolt can't seat all the way unless you shorten in. I didn't bother checking I just removed it as advised in this thread.
Yes there is no need if u do that. My logic was the original m35 calipers that the factory banjos screw into don't have an olive and the lines aren't designed to be used with it in. The reality is it probably makes f**k all difference and is a personal preference thing.
  • Like 1
Use a self tapping screw. Screw it in till it stops or until the olive starts spinning with it then pull out with some pliers. 1 I took out came easy as the olive started spinning. The other was a bit of a bitch but came out eventually with a bit of CRC and some careful pulling.
  • Like 1
  • 2 months later...
Hey anoyone with big brakes, don't forget to check your spare if it fits.
Mine doesn't even on the back with 12mm spacers.
Need to source another rim with matching size and offset from a wrecker.
Lucklity I had a flat in the city and not down the snow where i was 2 weeks ago.....
My spare has been sitting in my garage for quite some time. No point in having it in the car as it doesn't fit unless I put two 25mm bolt-on spacers on the hub.
So i decided to go with THIS
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
