R34 Gtt Induction Box Do It Yourself
Guest TR34GT
Hi SAU members.
As promised, my son and I now post the pictures and instructions for the DIY induction box, which is now finished, installed, and working like a treat.
The best thing about this exercise, was that the whole deal cost just $40. (with a few bits lying around too)
The car had an HKS Superflow pod filter, which we were trying to make legal.
The steps we took were as follows:
1. Buy a pices of 2mm thick cardboard from the paper shop.......around 400mm x 600mm - $2.00
2. Cut to the approximate shape to house the filter (car specific fit) using the existing GTT mounting points and trial fit until you get the approximate correct fit. The dimensioned template we made is shown in the attached pictures.
3. Buy a 900mm x 250mm x 2mm think peice of scrap aluminium polished sheet - $20
4. Mark out your template on half of the aluminum sheet and cut out with a jigsaw
5. Mark out the approximate fold lines on the aluminium
6. Fold by hand across the fold lines in the directions with a gentle constant pressure across a rolled flat edge
7. Drill 5mm dia holes in each of the end lugs
8. Trial fit a million times to get it right, and keep filing, cutting and massaging until you get the thing to fit perfectly.
9. Cut out two 80mm x 30mm peices, and round edges to for the top fixing mounts, bend at 90 degrees, after drilling two x 5mm holes in each lug side (see photos)
10. Fit top fixing mounts to side as shown using 2 x 5mm x 25mm high tensile steel hex bolts, washers and nuts.
11. Install your new heatshield using the existing mounting bolt and one new 25mm x 5mm dia high tensile steel bolt (see pictures) - $6
12. Cut shape of top out of same cardboard and trial fit so that it does not touch any of the chassis edges of the engine bay.
13. Cut out the top out of the other half of the aluminum using your template.
14. Mark out exact drilling points through top, to match fixing points and position in engine bay.
15. Trial fit another million times until its just right.
16. Remove all, and hang by lugs in a fairly dust free sterile environment (sure, we used the garage)
17. Spray Knights grey primer on all areas (touch dry in 15 minutes) - $7
18. Spray Knights engine enamal (gloss black etc) covering all areas till desired effect is achieved. - $7
19. Leave for at least one hour
20. Fit and glue on a rubber / foam edging across the bottom.
21. Fit all as shown, and dress with whatever vinyls you want (Mines in this case)
The project took a full day.
The installation is solid, with no vibrations or noise, and I think its now made that pod filter legal.
(At least we hope so)
Anyone wanting any help, or any additional information, just email me.
Regards
TR34GT (Jim)
very nice job man, looks heaps pro.. Just a quick question. With the stock snorkel gone, where is the heatshield pulling air from? I know its pretty tight on the underside of the filter esp. with the stock cooler piping there, did you route a CAI into the guard too?
Also, did u notice a difference? is it quieter? more power?
Edited by Angelecles
Guest TR34GT
very nice! i'll have a go at this myself.
do you have larger versions of the pics? more importantly pics of the measurements as they're too small :blink:
thanks
R-Spec,
Many thanks.
If you open up each pic in your browser and in the bottom right hand corner, increase the magnification to 200%, the pics should be ok.
One thing I didn't mention is that at the chasis mounting points, I used a 4mm thick x 6mm dia reinforced rubber fuel injection hose between two washers, around the 5mm bolts, as anti vibration mounts. Don't forget those.
I hope all works out.
Remember to trial fit 500 times and the result should be good.
Regards
Jim
Guest TR34GT
Angelo,
On the GTT, there is a direct opening below the pod filter position which leads straight to the left hand grill openings in the front bumper and behind the the bumper.
No air piping needed. (I hope)
The noise from the pod filter was not reduced, however, if you were to also line the box with some sound deadening material on the inside, you might just quieten the ride.
As far as more power, there doesn't seem to be a difference, however, I'll try and route some 3" flex tubing directly to the pod, and see what happens.
I'll let you know.
Regards
Jim
  • 4 weeks later...
  • 3 years later...
  • 2 months later...
Hello Guys
Here are some pictures of my DIY induction box and snorkel, following some of Jim ideas
post-65874-0-44202400-1307504202_thumb.jpg post-65874-0-83250800-1307504238_thumb.jpg post-65874-0-41791900-1307504271_thumb.jpg
post-65874-0-74188900-1307504346_thumb.jpg post-65874-0-27018800-1307504392_thumb.jpg
Love this idea here, Gonna give this one a go but rather than make a wall in front of the pod(where the headlight is) ill leave it open so air can come through the head light area.
  • 1 year later...
Hello Guys
That looked awesome dude.
hmmmmmmmm................................carbon fibre!!!!!!!!!!!!!!!!!!! :-)
Edited by TR33GT-001
  • 2 months later...
Hi SAU members.
Regards
TR34GT (Jim)
Wow your set up is so clean
Good work !
What intercool kit are you using ?
And did you have to cut a hole for the cold side ?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
