  • Replies 41
my 31 fill the criteria
diffrent to cars in the mag ( yup lots of scratches porry looked after)
interesting things (its got mags)
do people want to read about (tough one but i say if you put it in the mag *** em they will have to read about it)
but anyways yea get some track day coverages
pete
Originally posted by benhpi
We're happy to feature import R31s in HPI and the local cars can go in our sister mag Zoom if they are something special.
mmm.... awesome!
we've got some HOT ones over at R31skylineclub.com
Even hot Oz imports... RB26's etc etc.
there are some bangers that's for sure.
PM sent
Originally posted by Bl4cK32
How bout comin to Adelaide for the next drift meet? Apparently they've got all places filled, and it isn't on until next month.. They were even talkin bout buildin a specialized drift track.
We will be covering that event and entering our own drift car. Actually we have been involved in the design of the new track...
Russ as its only a training sess they may not be interested *shrugs* .... unfortunately perth lacks places to legally drift.
But Perth Auto Salon is coming up in October ...... quite a few cars are getting prepared for that at the moment .... ranging from R31 old schoolers to R34's.
As for my cars ..... if u need to borrow a Z31 turbo in good condition (yes there is such a thing :P ) u know where i am ..... Nizmo my R33 looks mean from the outside but otherwise inside n engine are stock ;)
Keep up the good work with the mag ;)
Lauren
Originally posted by Duncan
A great article would be on one of our trackday outings at Eastern Creek, we've been getting 10-20 cars a regular basis, from stock to monsters.
That would be a top idea for an article seen everything from a R34 GTR Nur to an R31 on these track days.
A frined of mine has a KE55 corolla coupe he has built to 95% the same spec as a JDM TE37 levin, including JDM tailights, bumpers, Black racing (rs-watanabe style) rims, interior, and a 2T-G with dual mikunis and a T-50 box. Its currently off the road with some drift damage being repaired and a 1.8 litre high comp bottom end and 256 cams going in, as well as front coilovers and some rear end mods. All it needs is the levin grill/lights. When I say same spec as a TE37, I really mean the same spec a young hashirya would have built his te37 to in the late 70's..
http://www.tassie.net.au/jar
those pics are old though.
Theres also a guy here with a KE10 corolla coupe running a 4AGE 20V (might have a 7afe bottom end IIRC), which is also done up in a retro japanese street racer style (e.g japanese rego plates, old school wheels) .
I guess they aren't *totally* imports, but in both those cases there is really no "australian content" componentry left.
retro feature...
cheers,
floody
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
