  • Replies 66
Posted Images
What did you do about water and oil lines? also did it require a spacer plate?
How have you found the internal gate? No boost creep at the higher end? :thumbsup::D
Sorry for all the question!
Cheers mate
Water and oil lines were custom made by Pirtek, using some special grade braided lines.
Top mount manifold, so no spacer required.
Also got the HD actuator through Slide and it's working really well, no boost creep at all.
My setup is not the best comparison as i am running a RB30DET.
Here is a graph (run-in tune), just to show you the boost curve of my set-up.
Solid line is boost.
oh so when i tell him the pump is the problem last night no one listens to me *starts cutting* :thumbsup: ha ha
but yeah it will be the pump for sure i had the same thing happen to me! I used a Bosch 029 after the GTR pump ran ot of flow, good for 700hp :(
Can someone confirm that the 3071/3076 need the oil/water line kit when you buy the turbo? I know some people use factory lines but i'm unsure if the garrett turbs need the kit.
Cheers
it needs the kit
it needs the kit
+1
BUT! don't get the gcg one. Even though the rubber lines have a flame proof sheath they aren't melt proof......
One of mine was lucky not to have melted through and dumped the coolant everywhere. The other one is pretty heavily discoloured even though it was tied close to the block well away from everything hot.
Luckily as the turbo is off having the waste gate ported i have the opportunity to get it fixed.
See the fact is My walbro pump hasnt shown signs it is caving in
What pump you guys recommend to changing it to
are you serious?
how about the fact that your injector duty is way to high compared to power output.
thats a major sign its caving in.
its obviously not keeping up with the flow rates required at high revs and boost.
mount a 044 intank and whatch your AFR drop down into the 10:1 range.
are you serious?
but his awesome tuner would know more than you right :D
Common Boys ............................. No need to rip in to everything
Man i brought the car to him he tuned it
I presume bel garage know what there talking about tooo
ha ha sorry! They wouldnt be the first workshop to make that same mistake (the one i went to told me to change injectors too) so dont worry too much. Just next time you are there mention you might think it is the pump and not the injectors and see how they respond, im sure it will be one of those 'why didnt I think of that' moments and everyting will be sweet
As for coils. Man you need them as then will miss fire hard
i also just thought i would ask who told you this rubbish?
the standard coil packs are of a very high quality and produce more then enough spark for up past 350 rwkws.
dont replace them unless they "prove" to be faulty.
ive been running over 1.5 and up to 1.8 bar since back in 06 , with standard coils and iridiums, and have never had an issue.
bell garage told him, and convieniently had a set of spitfires in stock. lol
f**kn helll you guy are bad
it is like you are arguing with a bunch of kids
i presume that spitfires and better than 13yr old coils
you people just dont understand
our car are not brand new there about 10 - 15 yrold.
As for a walbro there is the shit ones and good ones
you can produce over 350rwkw on it....
maybe your machanic need a tune up
fella were not arguing with anyone
the $600 spent on new spitfires is a total waste of money if your stock onces are in good nick.
theres heaps of guys on here with 200kws running spitfires. and i bet a lot of them would have 6 perfect coils sitting at home in the shed, but they rush out and buy them thinking that they are needed to make reliable power.
or because they were given bad information.
until you change to a real fuel pump and watch your afr's change drematically you can keep thinking that walbros are the best pump in the world. genuine,copy,gold plated i dont care. up to 250 rwkws. awesome pump. over 250 rwkws, thro it in the bin before you lunch your motor.
if your still not convinced you will be when your ringlands let go, and you spend $10k on a forged motor, boost it to 20 psi and watch your afr's hit 13:1 with your injectors at 100% duty. maybe then you will realise that some of us on here, that allready have done all these mods are trying to help you. if you want to learn the hard way thats fine go right ahead, but just be careful how you word things because you dont want to misslead other people with here say or miss imformation.
attached is my original walbro, which contributed to my ringlands collapsing.
which was the replace with a 044 intank, running a v8 fuel sock.
AFR's are much more stable and accurate with the constant flow from the 044
another question...
will my stock bov be up to the task if i am to run 17 psi on this turbo?
ive been quoted on a turbosmart full plumback bov. for around 400
what is a cheaper option regarding plumback bov's?
I was told [note not me, but told] that the stock BOV will not cleanly handle the extra flow. But there are several shops that will mod your std BOV so that it can, mine was done when I installed the GT3076. Its no bling bling bright thing, it looks bog stock [which I think is good], but so far it has worked. And the mod didn't cost the $400 a HKS/Greddy etc BOV costs [it may not sound as good either, but I DGAF about sound].
Others on here may have different idea's.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
