Thats alright man, wait til I have it all set up with some gripy tyres next time, Will be alot faster
:) yey! can't wait !!
Nah, that guy was a toss, Zane was the guy with the jumper
Oh right, i looked at him, im like dude you serious! me in my jumper + 10 shirts lol, his in a singlet mmm :D
  • Replies 344
Posted Images
Dam it i got beat on the second skidpan!!!!!!!!!!! dam missed a cone on the frist run which F%$Ked me over. Tek GTR can never lose.
Dam the back track was heaps faster in the arvo.
7&23 better be GTRs not a pesky EVO
I drove car number 7.
So this event will be held again in August ??
Tim.
Good good only R32s that beat me and bring the next one. I was 28
TURISMO thats a great time on the back track 1.44 in the morning was super fast!!
Thanks man, that's when my tyres were only bald, not delaminated
Full frame/Graig did you get any shots of my car doing a little smoke show? I really love that pic of my car on the freeway! and that you shopped the dent out of my bonnet in one of the pics LOL
Thanks again for the jack :thumbsup:
Its about time!
If you find one for like $500 thats manual let me know, ill get one aswel. Yes im serious
i got a manual wagon that i will sell as is for $500. at the mo its got cut springs and a rooted cat and rear muffler. i was gonna replace shocks and springs with peddats lowered springs and KYB shocks and fix the exaust and sell for $1500 with rego and RWC
altho it is in canberra. either way let me know if you interested
DM
Anyone who has footage or good stills and wants to contribute to the club version of the DVD, contact me ASAP via PM or email , matt AT ignitiondvd.com
wooop! :w00t::rofl::laugh:
I'll burn you a CD and hand it over at the AGM if you're there. :D
If you're not i'll give it to Adam or Sammeh to pass on. ;)
Its about time!
no one will ever get a bargain again like my first Skyline- a manual R31 GXE sedan with 9 months rego for $750 :w00t:
should have kept it...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
