  • Replies 128
Not in Melbourne,
But DTM Autos in Geelong seem to know their way around it, and can even fit a seperate transmission ECU if need be. Certainly know the box well enough in my experience (experience = calling around about 50 places and finding 1 who isnt WHOA R34 NO THANKS)
Not in Melbourne,
Thanks Greg! Good to know there's someone in the state who knows these boxes...
Still looking for someone closer to home before I hike down to Geelong, inner Melb preferred if anyone's got recommendations?
  • 4 months later...
or you can hike down to adelaide and visit mv autos.
Lol funny I find this again.. My car is now at DTM.. As the MV kit I had in it killed the trans in about 10,000kms.. This wasn't really due to the MV kit as opposed to having a valve body for a turbo ecu car in mind.. The stock n/a shift computer doesn't pit nearly enough line pressure to stay alive. Keep in mind if you have a GT and put a turbo engine in front of it.
Moving on - does anyone know where to find the wiring diagrams for the r34 non turbo auto transmission standalone ecu? Dan666 where are thou?
  • 1 year later...
hey my name is Steve
i just joined as i have a problem with my new car i bought four days ago guy told me that its stuck in 3rd gear 1,2,4 gear does not work i have been told it is a solenoid and then an inhibeter switch sorry my spelling i am Afrikaans and English is not my strongest speaking language.
the car i have is a skyline r34 gtt nismo skyline fourdoor rb25det fully stock in and out and its triptronick have anyone fixed this problem and can give me a answer asap as just waiting apon the part that i will need to fix this thanks
The transmission is in limp mode, possibly the fluid temp sensor is faulty?
You are going to need a Nissan consult I think, or a good reader with a consult adapter, to get the code. A good trans specialist should have this, at least then you will know if it's worth fixing.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
