A new Nissan plug in ecu is soon to be released on the market. A direct plug in running off all factory sensors and controls. It will be laptop programmable with full data logging, launch control, anti-lag, flat shift etc. The ECU will be supplied with a base map tune to suit a STD car and will feature a tune suited to aust. fuels and conditions. Will also feature dual map facility to switch between a race fuel tune and pump fuel tune at the flick of a switch. Red R Racing is looking to be part of the distribution team in Australia.
stay tuned for more info...
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/218179-new-plug-in-ecu-coming/
  • Replies 895
keep me in touch mate! by the way, what brand? how much are we looking at? tuner and dealer?
cheers
ill provide more info in the next few days, this ECU will rival the quality and features of MoTeC and Autronic.
just a few questions,
sounds good so far.
so is it a piggy back to the nissan ecu not a standlone item?
if you dont have a laptop how else can you display infomation or does it come with a handheld VDU like a apexi power fc?
will it have full australia return to base warenty?
is it user friendly? ie it being a new ecu are there any tuners out there that have experiance tuning with this? or will it be a case of you having to pay for a tuner to learn with your car at your expensce to become familary with this ecu?
who makes this nissan plug in ecu?
what country is it made in?
terms of warrenty?
Deff a good idea of having a switch to flick between fuel maps. so you can have one map for racing ie rich and one map for economy right?
sorry for questions just a few that come to mind.
cheers
rob
so from what i understand it will basically be a nissan badged version of the EMANAGE ULTIMATE.
which is great >_<..............................IF u can find a tuner.
GOOD LUCK :bomb_ie:
If its suppose to rival the Motec and Autronic,there is no way its a rebadged Emanage Ultimate mate.
sounds good so far.
terms of warrenty?
cheers
rob
its a standalone ecu...much like any Power fc
no vdu but may interface with current display dashes currently on the market (ill find out and let you all know)
full forum/net based technical info and full factory back-up and warranty
very user friendly, any tuner who knows how to tune Haltech, MoTeC, Autronic and Apexi should have no problems with it
will inform you who makes the product as soon as its ready for release
made in Australia
more info and full feature details will be available soon...including price.
Nope , doubt that very much .
No way manifold pressure sensing can achieve what mass flow sensing can , I guess people can't get their head around the fact that the appropriate MAF sensor is not restrictive .
I had been just about to ask if the new box supports larger than std MAF sensors like PFC's do but no point is there .
Lost me , cheers A .
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
