Nope , doubt that very much .
No way manifold pressure sensing can achieve what mass flow sensing can , I guess people can't get their head around the fact that the appropriate MAF sensor is not restrictive .
I had been just about to ask if the new box supports larger than std MAF sensors like PFC's do but no point is there .
Lost me , cheers A .
Power FC Djetro cars dont run as well as AFM models...is that what your saying?? AFM reversion, stalling/overfuelling, etc...not a problem with AFM equipped cars??
To each their own i suppose...
Boost control...yes
Edited by DiRTgarage
  • Replies 895
come on man your killing us (and i bet your enjoying it slightly)
out with it... :)
ill have a further discussion with the manufacturer tomm. and see if i can leak a bit more info pre-release
but yes...im loving it :D
any questions you would like me to ask please feel free to list them...OK
a price range would be nice
unless you're going to try and milk the market
as you may or may not appreciate...this is not my product. As a potential distributor i intend not to jepardise my relationship with the manufacturer by quoting prices or other information without their consent. All i can say at the moment is it will be dearer than a new Power FC and cheaper than a MoTeC.
Im just providing a little 'heads up' pre-release so you have a bit of background on it.
sounds interesting cant w8 2 c wat it will be like. another q is with the tuning will it come with a cd with the software 2 install on laptops 2 tune it or will this have 2 b purchased seperatly. and with the boost controll can it still run with other boost controllers like the greddy profec 2
boost control function is able to be done separately to the ecu.
software supplied and updates available on line through internet/email
How long away is this thing from being launched?
will get a date for you tomm.
we are going to run one of these in our 9 sec drag car to see how they handle a high power race application. The flat shift function will be interesting to use as well as the two-step launch limiter.
wow you obviously have alot of confidence in the product " or alot of spare cash" just incase its not what its cracked up to be.. lol
on a side note, so happy its a map sensor based system, airflow meter's suck..
Is it a megasquirt with some electronics to suit skylines attached?
Thats how I planned on adding all the features you mentioned to my car using as little money and R&D time as possible, I got majority of the way there too. Open source that bad boy and make all your money on hardware & tuning, people will join you in making it truly competitive to motec and autronic.
ZOMG full hektic sik bro!
wifout da afm i can run da siiiiiiiiiiiik dose!
seriously tho.... pfc's are the fav because of tuning availability..
does it run the climate control and other shit?
also interested, depending on price mainly...
I feel like I know you a bit Paul, and you wouldn't put your name anywhere near some POS item :)
I'll be needing an ECU fairly soonish, so lemme know if you need to test a street application :thumbsup:
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
