A lot of the initial hesitation for going to the Vi-PEC by Power FC owners was the lack of a dash mounted interface unit. This is what most wanted so this product is a perfect solution.
Another solution would be to buy an old Game Boy from a garage sale for $10 and throw it at their thick heads.. haha.
  • Replies 895
The Ruzic does seem to fill a gap, but the point for a data logger and dash is so that you can run sensors not associated with the ECU. A dash that only takes inputs from the ecu is great as its plug and play but doesnt tell you some other things you MAY want to know. Thats where a wire in dash MAY be better for some people
Would it be possible to wire in your additional sensor to one of the spare Vi-pec analogue inputs and then get the Ruzic to display the new input? Would be a nice and tidy solution. Plus you could get the ECU to react to that input, datalog it, whatever..
umm, you'll find that the RE engine monitor does take inputs from any sensor you want. It's just been customised to work in direct link with the Vipec. You can wire in more sensors if you like.
The datalogger does everything a Motec logger can do.
You name it, it has it
Hi, Paul Ruzic here. I designed and built the EM PRO II and RaceLogger. I will happily discuss the technical specs of the unit but cannot discuss pricing or availability as per forum rules.
The EM PRO II was originally designed as a stand alone unit, then dirtGarage made the introduction to Ray Hall and the ViPEC ECU. So now if you have a Vi-PEC you can plug it in and reallocate all the normal inputs the EM PRO II already has to other channels expanding its monitoring capability.
Technical Features:
6 analog input channels
Engine RPM input
Vehicls speed input
Remote data page push button
Remote alarm acknowledgement push button input
2 Stage shiftlight output
Warning light output
Alarm buzzer output
Auxillary output for a relay triggered by RPM or Speed or for PWM electric water pump speed control.
Serial data output for loggint with the RaceLogger
Serial data connection to the Vi-PEC ECU
The EM PRO II has 5 data used to show details of each individual data channels that are being monitored. Each of the pages can be configured to show up to four input channels at at time. An optional remote input button mounted within easy reach of the driver can be used to scroll between the pages.
Each monitored channel can have a "greater then" and a "less than" value assigned to them. The alarm situation can trigger the warning light / buzzer or both.
The proiority of the alarms can be set so the most important alarms are always at the top.
Up to three alarms can be seen on the screen at once.
The alarms can be set to hold for a minimum time so they are never missed or to not clear until acknowledged.
To ensure oil pressure is maintained through the rev range, the EM PRO II has two additional oil pressue points that are set referenced to RPM.
Without a Vi-PEC you can piggyback signals from the ECU (so far we have done units in cars running Motech, Haltech, Autronic, PowerFC) and also provide addtional sensors for signals ECU's don't usually support such as Oil Pressure, Oil Temp etc. With a Vi-PEC you can still add up to 6 additional channels using extra sensors.
Vi-PEC Channels Supported
RPM
Knock - also allows option to alarm knock against the Knock target table
MAP
MGP
Injectory Duty
Injector Duty (stg)
Coolant Temp
Air Temp
MAF gs
Knock Count
Temp 1
Temp 2
Temp 3
Temp 4
Volt 1
Volt 2
Volt 3
Volt 4
Volt 5
Volt 6
Volt 7
Volt 8
Volt 9
Volt 10
Volt 11
When connected to the Vi-PEC data logging is performed with the Vi-PEC ECU. When stand alone the EM PRO II can be connected to the RaceLogger to add to the logging capabilities of the RaceLogger.
The EM PRO II has external Shift lights / warning lights and a large alarm buzzer for optimim setup for racing. The external page select / alarm acknowledge buttons also allow for driver convienient mounting for racing.
I have to also thank guys like Paul, Darren, Duncan, Mick, Noel, Gervase, Simon, Danh, Cam, Mark, Mitch, Pierce and others (you know who you are) who have supported this product through development and testing.
Thats the quick overview of the unit. I almost have a brochure ready (thanks Cam) which will detail all the information.
Sounds the biz...apologies, from what i read in other posts regarding the ViPec doing the logging etc and the fact that it was plug in i assumed it didnt have any external outputs for logging. So its great that it has 6 external analogue channels!
Any other screen shots. Is it always 4 lines? You say 5 pages with each page beign able to show up to 4 channels. Does that mean you can only show one or two and get bigger font/readout on each page?
Considering your car is for mainly track/circuit work (I am assuming from your thread in the motorsport section) why did you not go for an aftermarket dash such as that offered by Motec, Aim, Stack... etc?
Mike
That question has pretty much been answered the price and the fact that the Ruzic Engineering gear does the exact same job as the AIM etc but for a price you cant go past.
A mate of mine who's car I do all the work on has just ordered an AIM dash that has the same functions as the Ruzic gear and it is $3300.00 wich may be ok for him due to the budget he has to support his racing. But for me it makes more sense to use a product that does the same job without any compromises in its performance leaving me with more money to put into other parts of the car.
Edited by dazmo
Thanks dazmo
PS: feel free to update your thread in the motorsport section, love the R33!
Thanks Trent for the info regarding the boost function. I am still undecided whether I should ditch my Blitz dual SBC or keep it.
Thanks also to Paul Ruzic for allowing me to test out his new products and for his patience with the development because I can be OCD sometimes lol The great thing about Paul products are their flexibilities and ability to customise to your needs. Paul doesnt leave any rock unturned and covered all possibilities before releasing his trial products. I've been testing Paul's EMII and 4WD controllers. Both have worked flawlessly and gave me more confidence in what I should be doing on the track.
Now that his can be hooked to the vipec, I might give the vipec a try.
I wont go overboard here and will write more feedback in the appropriate Ruzic thread.
Anyway the endless ability to program the shift light, warning lights, warm up lights and buzzer are awesome.
If you think dirt's image is bad, don't laugh at mine ok.
Sorry, my lens did not like the inadequate light in the shed. I will take some more pics when the v88 is installed.
Edited by 9krpm
Hi Roy, the display is 4 lines of 20 characters. The display can easily be read from the drivers seat to any mounting postion so there isn't a need to join lines and make them bigger.
You can setup the pages however you like, one guy has put oil pressure at the top of every page as he likes to see it all the time. You can make pages with 1 to 4 items.
Thanks for great feedback dazmo, 9krpm.
Paul
Paul
LOL, you guys must have better eyes then me and a smoother ride at light speed on the straights. At speed when i glance down to look at things i cant read the Power Fc readout if it has any more then two lines being displayed, even when on steering column.
Thats where the alarms and warning lights are great...just means you have to se them conservative so that you know when you have to start looking down
Roy, this thing is so much easier to read than the FC hand controller display.
In the event of a malfunction, the warning light and buzzer go off, the screen switches to a warning menu and lists the faults. There are also programmable warning pattern, duration and ways to turn it off.
It has enough warning lights and functions for me to keep an eye on my Willall racing built engine. Now that the vipec is on order, I think I will have less worries on the track :D
Edited by 9krpm
I mounted the datalogger in the glovebox (since you only need access to plug in USB storage, and that cushions it a bit from shock) and the EM2 unit is on top of the clock which is easily seen thru the steering wheel. Mine is running with a PowerFC sniffing 6 channels from there and about 10 other items from elsewhere.
Sorry its a bit off topic but they are an excellent unit. Probably need help with install if you struggle with electrics like me though lol.
u should try installing them with non matching colour codes :banana:
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
