  • Replies 172
Posted Images
LOL, hopefully Lee and Matt get a good run in and we can all try and pump out some PBs or at least respectable times
If anybody needs some semi slicks then let me know by Monday. I have some credit that i wont be able to use all of. So can use the balance of the credit to redeem some cash from whoever needs tyres
well my car is running sweet but ive only done 150 ks on it so far wednesday im doing the first oil change
do you guys reckon its advisable to be racing it only after like 2000 kms???
or should i sit it out and wait again :D till the next one??
what do you's rekon id dont wanna screw it like last time lol...
if its built and tuned right you should have no problem.
have you changed anything in the brakes or suspension since PI?
no i havent done anything with the brakes yet but is most likely my next mod when i get some cash again
i wont run it too hard anyway
its just about gettin out there and driving the way that you aint alowed to on the street
...oh and no GTRs :( Will have to see if the GTSt / rwd boys can take over and keep the WRX crowd honest at the tops of the time tables :)
I'm in. Car is ready after a bit of unscheduled maintenance and a visit to the EPA.
hey with the whole epa thing is there any way of tuning your car down to pass the requirements even with a few mods??
Weld a baffle into an old Cat so that only half the exhaust gas can pass.
But if you have aftermarket ECU then EPA wont pass (if they find it), so de-tuning via ECU is probably not the answer.
I like the way you think...
do you know anyone who's tried that??
im gettin worried about cops i was at the petrol station just filling up and this cop gave me the biggest dirty look like i was a criminal or something as i walked to my car and started her up. (he probably wished he had one)
he stared at me for ages.. too bad his partner was inside the p/station and he couldnt pull me up as i drove off.. (Slowly)
anyway back too the subject i think ill come along but ill sit this one out.. probably wont have my final tune ready till late next week.. :)
LOL - I just looked at the entry list and there is 7 GTR's on there. So I don't know what you're talking about. Not that it matters as they'll all be trailing after the WRX of Clayton.
But are you entering Brisby?
Oh - and does anyone know if the pads from the Alcon 6 pots are the same size as the pads from the AP 6 pots?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
