So what you are effectively saying is that compared to your last visit to Sandown your braking longitudinal G's are down and your cornering lateral G's are also down - but yet you managed to set a new PB for Sandown! That's a fair effort :D
An extra 40kw does wonders - more straight line speed outweighed less corner speed and reduced braking performance.
  • Replies 172
Posted Images
How's that yellow snow Andrew? :blush: Trouble with linking to images on a server in someone else's control is... they can just replace the image :D
See attached for the practice session times for group 5 :thumbsup:
080601_Practice_5_Lap_Times.pdf
Not sure how many of you guys are running video cameras in /on car but I just found the perfect double suction cup mount for a pencil/webcam.
Bought one in ALDI called a "Bath or Shower Support Bar" for $9.99 !!
PERFECT! Double suction cup safety prob could hold a handy cam as well they seem so strong on a decent flat glass or metal surface.
Works great with a $80 Eight (8) Megapixel bullet webcam "SPEED S8850i PC Camera" at 800 x 600 32FPS USB connection into my Laptop.
Just put a circular hose clamp onto the bullet cam mount around the mid handle and adjusts to any angle.
Great VIDEO for less than $100 - NOT inc laptop of course! :yes:
And what do you need software wise on your taptop to record
Roy, the webcam comes with AMCAP & VP-EYE software and the video drivers for the bulletcam
but you can use the native movie maker in windows or any other video capture software.
Will put up some pics soon.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
