hey guys
my stagea has developed a f**king annoying problem of just turning off. as in engine cuts out, but all electrics stay on (lights, radio etc.)
wtf is it? almost drove into a f**king pole when it decided to cut power mid corner. dunno how i stopped it...
car feels a little sluggish lately too. dunno if thats related or not. ive noticed now that when u goto take off, you can feel it hesitate. is that just the boost when it goes from 5-7 or whetever it is? ive never felt it before
ive been told it could be fuel pick up related, where would i look?
ive cleaned AFM thinking it was that for some reason, didnt fix it.
it only happens in mornings too, grumpy f**k.
im at a loss at the moment, and its got me f**ked what to do.
ny point of putting the nissan diagnostic tool on it to see if it shows a code?
hope u can help before i burn it to the ground!!!
cheers
jarryd.
https://www.sau.com.au/forums/topic/219486-car-losing-power/
hey guys
cheers
jarryd.
hey jarryd,
i have the same problem with my R33, i only noticed when i installed a turbosmart boot tee and BOV.. it was really bad when i first put it in then my mechanic said i needed to block the the vent from the original plumb back BOV... this worked but it was still cutting out, he also cleaned the throttle body which fixed it up a lil bit more.. it only cuts out maybe once every now an then, getting it fully serviced next week hopefully that may fix it..
in the mean time if you find the solution to this shitty problem please lemme know,
thanks
make sure your battery leads and connection is clean, and very good & tight (as in a very good electric connection)
stock bov?
I had this happen, like, 3 times in 5months while I used a GFB Stealth FX plumb-back BOV (from xmas to end april)
after replacing bov back to stock (put stock bov in vice and compressed tophat spring) and cleaning battery connections, its all good again.
but yeah mine went mind corner and I wasnt happy. lucky it was city street and was under 20kmph
Back somewhere, a couple of years ago, this popped up.
The day I picked up the S1 i drove 5k to a servo and she cut out while turning in to servo. There was SFA on the gauge and I thought "outa gas". She started and got to the pump.
The compliancer said "maybe shit petrol in the tank". Anyway it was fine for a couple of weeks. The bingo, it happens again.
Arf u#k, now what. Started again no probs. Got home and did the ECU reset. Disco the battery. Ignition on, pump the brake 60 thousand times. Re connect. Hey presto, never happened since.
Personally I think it is Gremlins from the #5 Factory.
If you're running an atmo BOV or standard BOV is blocked off it's making the AFR's go bonkers.
revert it back to standard if this is the case and then see if it gets rid of the stalling - I had this problem a few months back.
Hi
I am also having a similer problum. fueled up friday on the way home (same survo I alwayes use) the car runes smoothley until i want to overtake then it feels as though it is on the rev limiter.(at this point the engine has not cut out). I was toled it might be the AFM so I borowed one from a frend but it stil does the same thing.
Anything else I could try
Sorry if I hijacked the thread but I thort it might be related
Thanks
Phil
brendo - fuel filter was done last servie, but i will try fuel cleaner/octane booster.
just had car at my local nissan dealership, had the diagnostic hooked up to it, AFM code came up.
been told that Y61 Patrols with the 2.8l turbo diesel engine have the same AFM has the stagea/skyline.
on the hunt as we speak
cheers for your help
jarryd
edit: are all RB25 AFM's the same? or is there a difference between them?
stageas run S2 RB25 motors, am i correct?
first off:
take off the lid of the afm and clean it up, resolder the connections
should fix it
other option is to buy one 2nd hand off sau for $50.
ask around in the vic section if someone can give you a hand to re-solder your current afm internals
jarryd
Yep, Jaryd, the s1 Stagea runs the s2 R33 engine...
Also, run some (carby) cleaner through the AFM, it might help.
done that already, to no avail......
i've got an AFM, it's off an R34, but its the exact same as the S1/2 Stagea, S2 R33, and R34.
(it was used on a S1 stagea to diagnose a problem, so i definately works)
$125 and its yours.
cheers mate, ill let you know via PM
cheers everyone for your help, greatly appreciated...
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
