What: Dyno day on AWD dyno dynamics
Where: TM Autosports Unit 3/99 Gavenlock Road & Boswell Close Tuggerah
When: Saturday 19th July
Cost: $50 for 3 runs with printout
Time: from 8am
Prizes: highest na, 4cyl, 6cyl, 8cyl
Extra: will have a bbq and drinks put on at a small cost
We are aiming at 20+ cars, but can go up to 40. So if your keen for a run you will need to come along early.
https://www.sau.com.au/forums/topic/219507-central-coast-dyno-day-19th-july/
  • Replies 107
I work till 12 on saturday's, if i rock up around 12:15 will is still get my 3 run's?
If you know anyone that is goin and can put your name and money down in the morning or if you know you are definately goin i can put your details in. pm me with your details if this is the case.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
