Knowing Peter he would rip the VR38 out and put the RB26 in there, just cos its bettera. :P
Only if I turn the RB26 into an RB3.2, cos it is really bettera :yes:
Well you know what I am doing to the bottom end , now the head.
Do you think I should just clean it up a bit and put oversize valves and Titanium valve springs OR
Race port the head, 1mm oversize supertech valves IN/EX, valve guides, spring/retainers and shims
Might take the NISMO badge off the back and get a BIG RB320GTR one made up :wub: Oh and in RED because RED is faster :wub::wub::wub::wub::wub::wub:
Once it is all done I should be able to get to Woolies under 10s :woot:
Thanks , I am waiting for a reply from Jim to get an answer from some of the questions I put to him , basically what is best for the motor with this type of build .
I will have the torque I want so I really do not need to do it for that, so ????? :wacko:
This is now officially the Tt350gt / real NISMO1 build thread.
Hopefully a mod can change the thread title ;)
Can't wait to see the results. Should be fun! Be nice to be able to get what you want.
Yeh it is confusing, I did ask SAU to help.
I cannot log in on my laptop under TT350GT and I cant change anything?? I had to make a new Name , "The Real Nismo1". for my laptop and I cannot use both names on either of the computers and the laptop is great while watching TV or DVDs or whatever, so :whistling:
I cannot do many things on my laptop to do with this site for whatever reason :wacko:
But, as for the build , you blokes will think I am nuts but I do not want to take it to the extreme the 3.2 stroker could achieve but it will be great :yes:
Sorry for the name confusion :action-smiley-069:
Just been doing a bit more homework and I doubt if my Stroker setup will get over 400wkw on 98 pump unless I change the cams, double the Walbro pump and at least the Turbo housing as mine is smallish to get the response I asked for BUT it will have a lot of go with a shit load of Torque going on. So all good :wub:
My Haltech Platinum Pro will allow me to use both E85 , pump 98 or a mixture , might have to have a chip or something? I guess that will give me more if i want, but no one sells it here,haha :no:
HAHA , Thanks Ben, but all sorted and the thread is all yours :yes:
I see some go for years you are lucky once I decide, get the help I need its over in a week or 2 :whistling:
Let you blokes know when it is finished
Thanks everyone :action-smiley-069: well, OK thanks for the laughs Scotty :wub:
Haha,
I don't want the thread for myself. I have a 30 bottom end in my stagea. ;)
All the best with the build.
I'm sure it will be great and hopefully all done nice and quick so you can hammer down to woolies!
Haha,
when you say woolies....you don't mean woolworths right? :woot: or do you?
In my one I did very little to the head, clean and remove any rough edges that can cause turbulence and fit a set of BC springs, the stock head will flow 450kw without much drama
Hi Mick,Love to see some Dyno readings on this site,before and after 3.2 rebuilds especially torquey ones, maybe start a new thread to make a few blokes happy, happier,less grumpy :)
Tried to find some other thread but this bloody laptop needs a medic , try on the PC after golf, lifes a turd :)
There is, well not so much before and after more just different setups and their result in the Forced Performance Thread home page at the top there are dyno result threads
http://www.skylinesaustralia.com/forums/topic/104332-rb30-hybrid-upgrade-all-dyno-results/
http://www.skylinesaustralia.com/forums/topic/93880-rb26-turbo-upgrade-all-dyno-results/
This are the two most relevant for you
    • Hello First, I apologize if this is not the correct forum. Let me know and I will move it to the correct one. I'm having a problem with the tachometer on my Skyline R33 with an RB25DET Neo engine. I'll tell you from the beginning. I'll tell you from the beginning. I have the RB25DET Neo engine installed in a Nissan Patrol GU, with a Link G4X control unit specifically for that engine,  and I have fitted a Skyline R33 tachograph to the original GU dashboard, but it doesn't work properly. I have the tachometer connected to the positive and negative terminals of the GU panel's wiring, and the signal cable is connected directly to the ECU output pin, but the rpm fluctuates widely. Can anyone tell me if the output signal from an R33 ECU is the same as the output signal from an R34 ECU, or if the voltage and signal type are different? Regards and thanks.
    • I guess it was the thought about "Oh if I were to drive this everyday". Then no, SL500 I wouldn't really consider lmao.
    • Yeah actually really fair point. Idk what I was thinking when looking at the SL500. Now that I think about it, I feel like I would have more enjoyment out of a shitbox that I would need to repair than some fancy merc. Although I must admit the SL500 does look quite nice. My bad hahaha.
    • 100% Also "Not wanting to spend money" is THE WORST IDEA IMAGINABLE when coming to a project car of any kind. They EXIST to BURN MONEY. Sure, gas money is a thing. A stock car with the worst fuel economy ever sold would probably be cheaper than modifying a car with FREE petrol for the life of your ownership of it, lol.
    • Amount of time you're being observed by law enforcement is so minute, that you could be a dumb shit 90% of your driving time, and never lose a demerit. You could also be the best driver ever and still get hit with a fine.   When you realise how quickly everything turns from "Wee, we're having fun!" To "oh f**k oh f**k oh f**k", you start to realise the only way to be a good driver, is to not be doing anything dumb or unexpected by normies on the road. You want to go fast, go to the track. Someone there in a 1990s slow POS will also show you how bad of a driver you are as they lap 10 seconds per lap quicker than you can in a car that should be considerably faster.
