Please bear with me as I tell the whole story from the beginning .. it's not very long I promise!
I bought a stock standard R34 GTT a few weeks back with 62,000 Kms on the clock. The car seemed in very good nick, albeit no performance mods. So the next day (so to speak) I got a turbo back exhaust from justjap (front/dump pipe, highflow cat and 3" catback) and noticed a smoother drive and the boost was coming on earlier too (around 2500 rpm instead of 3000) and I was a VERY happy chap... until...
I took the car for a timing belt change since most of the drive/psteering belts were very worn and/or cracked (and who's to know the car's odometer hasn't been messed around with so it may have already done 100k).
One the timing belt was changed, I came to pick up the car and on my way back home I immediately noticed that the car didn't feel as if it had as much 'oomph' when the boost kicks in as it did before .. (to this day I'm not sure if this is just all my imagination). So I asked around and someone suggested that a timing belt off by one tooth could explain the perceived loss of power.
So I thought I might as well take it for a dyno power run and see what I get at the rear wheels. I took it to Bel's Garage (very pleasant and helpful peeps) and after 2 runs we noticed the car was doing only 143rwkw. The tuner thought that's probably about right and I said it sounds a bit too low as I was told that a stocker should get 150-160rwk and a full turbo back exhaust should probably add another 15kw as well so I was hoping to see something like 175-180rwkw but instead what we got was 143.
So he spoke to his mechanic who came over with a timing light and reckon the timing was right but then he noticed that the ingition timing wasn't reset to the default 15deg, instead it was set to 5deg only. He said whoever changed the timing belt, rushed the job as the ignition timing should be at 15 atleast so he cranked it up to 17. Both the mechanci and the tuner at this point seemed confident that this explains the low power output and that we can expect a lot more on the next run ...
So they do another dyno run and lose boost at 6psi and everyone's scratching their heads ... the mechanic says he reckons the actuator must have got stuck when open. Turns out he was right .. the actuator was stuck open apparently because the aftermarket dump pipe from justjap wasn't fitted properly .. So he fixes the actuator and we do another dyno run.
And this time we don't lose boost and the car does 145rwkw (2kw increase only since fixing the ingition timing!!!) and everyone's scratching their heads again "should be a LOT more than 2kw increase" they reckon.
At this point it's already getting late so they can't do any further diagnostics and put it all back together. The mechanic tells me he has no idea why it's making 145rwkw only, even after fixing the ingition timing.
So here I am now .. totally deflated and disappointed. I guess I probably should have gone in with lower expectations than 180rwkw, but 145rwkw with after-market turbo back exhaust just doesn't seem right. What do you guys reckon? What else could it be ?
Could it be the coilpacks? Maybe one of them is dead ? Anything else that could explain the lacklustre performance ? I will post the dyno graph (final one) as soon as I figure out how to work this damn scanner.. Cheers
Edited by Delta Force
just confirming the only modification is the exhaust?
If said exhaust is x-force brand I'd look at that more closely.
I currently run a hi-flow x-force 3" cat and can only manage about 192 rwkw on a dyno run at 12 psi, stock turbo so boost trickles down to 10 psi through the rev range.
Mechanic reckons It's due to the x-force cat and I can crack the magic 200kw mark if I change to a decent cat, so doing this fairly soon to see if it makes a difference
Edited by Yo-Yo
because he advanced the timing ,it could be detonating (stock smic etc) and the ecu is backing off the timing
i would recommend the base time be set again and put in the correct 15deg spot
then do a stock ecu reset and try again
use some good fuel too and see how you go
yep, turbo back exhaust (and 18" rims) - other than that it's a stock car. The dump/front pipe is JJR, the cat is a highflow xforce cat (JJ guy reckoned he uses the same one in his GTR that makes 300rwkw) and the catback is an HKS Silent.
hey mate dont fret.... dynos are a tuning tool and many read happy(too high) your figure sounds about right to me... to put things in perspective i have an rb26dett 80,000 (legit) after having a ecu remap (power fc) cat back and twin pods i made 147 on 9 psi.... thats with a gtr engine and aftermarket computer...... what matters is that it feels solid and boosts nicely...e.g. no missing and runs correctly.
The mechanic was listening for detonations and he said it wasn't making any ... actually both him and the tuner were both surprised that there was no detonations/pinging at the 17-18deg setting, they said most skylines would do it at those settings. In the end he reset it back to 15.
I am getting an O2 sensor installed hopefully sometime this week and they'll reset the ecu, I'll see how I go after that. Oh and I've only been filling up bp ultimate since I got the car (3 or 4 tanks now) Cheers
sounds about right, skylines aren't the 500hp beasts people seem to perceive them as and dynos are tuning tools, not 100% accurate power reading machines
My 33 (RB25, same engine as your 34) made 142.2kw with the same minimal mods as yours (turbo back exhaust). 150kw may have been the as new, fresh off the assembly power figure but over time it will lose a bit of power.
Edited by Baconer
See the thing is i wasn't expecting a beast but everything I've read before on SAU points to the 160-170rwkw figure for a stocker and additional 10-15kw with a turbo back. Are all those people just full of shit ? If so, why do so many make that much with the same mods and have it in their signatures?? Different dyno ??
Oh and another thing .. the tuner quickly looked up their database of previous customers and found another STOCK r34 GTT that put out 184rwkw. This was when he said 'hmm.. you're right' and called the mechanic to take a look.
I'm not trying to achieve the impossible but to me it seems 25% less power than a lot of other people with the same setup points to something not being quite right. Couple that together with the fact that I am pretty sure the car had a lot more 'oomph' before the timing belt change ..
145rwkw is low but still correct for exhaust only mod.
They are 145rwkw stock but if you allow a small variance for dyno accuracy then you could be making 150-155
Most of the 34's I have done make 180-190rwkw after boost increase to 12psi, full exhaust and a remap on the factory ECU.
Hm ok I just quickly searched for dyno results and found this r34 gtt auto (8psi boost) and he made almost 20rwkw more than my car and with the same mods .. just a different dyno?
What's this about remapping stock ecu .. i thought you needed a pfc to remap/tune the ecu?? please do tell me more!
I might take it to CRD for another dyno run as I heard they use a different brand ..just to see if I get similar results
I don't understand why everyones saying 145 seems like a reasonable dyno output for GTT R34, surely dyno is not an accurate tool to measure the cars power output but it must be pretty close to the kw its supposed to pull.
To be honest, the power ur pulling 145kwrw is bloody low cuz from my research and knowledge:
R33 GTS-T = 130-140 kwrw @ stock
R34 GTT = 150-160 kwrw@ stock
The results are for manual cars so if yours (Deltaforce) ain't manual that may be the partial reason why its low.
So you cannot compare the R33 RB25 with R34 RB25 Neo ok? its not supposed to make the same power. With an exhaust it could possibly push it up atleast 10kw without tune.
My recommendation for you is to go to a different mechanic shop to dyno run and compare the results if it makes any difference cuz if it doesn't and still stays around the 145kw mark, then definitely something is wrong.
Edited by R33Turbo
lol at 180rwkw - 200rwkw on the factory ECU and stock turbo...
150rwkw is about the most you'll get with a factory ECU until you get something you can tweak
So why am i getting 184kwrw with just cat back and 11psi boost? (stock turbo, stock ECU)
Maybe my dyno run was just inaccurate and is showing 34kw more than its supposed to.
Finally someone with proof to back up what I was saying all along .. thanks mate! :) Got a couple of q's for ya if you don't mind .. did you have your ecu remapped by any chance and if so by who? Any chance you did a dyno run before upping the boost to 11 ? Where'd you go for your dyno run? Cheers
Edit: yep it's a manual.
I never touched the ECU part of my car, i haven't remaped or used piggybacks so its still stock.
And yeah i did do a dyno run before boosting it to 11psi and made 161kwrw (bear in mind everything was stock including the exhaust). I dynoed it at Unique Auto Sports.
Edited by R33Turbo
Cheers mate, I'll try and get a dyno run at UAS asap and will report on the results.
O2 has no effect on power
Also that dyno graph - useless without the AFR plots.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
