hey guys, after reading NYTSKY's thread on his engine build i thought i might do one myself :woot: its great to get all sorts of feedback and information from fellow builders/enthusiests...
It all started after i put a GT2876 onto my rb20 with a few other goodies, then just before i got it tuned i did a quick compression test... 150 across the board...until i hit number 5, which was 95. put some oil into the cylinder and i then got 195 in cylinder 1... which told me the rings wernt in 100% working order and number 5 valve was leaking. which...from a 18yr old RB20 with 212,000 on it thats never let me down before, i expected the results, just didnt want them.
so i decided to refresh the 20, worked out the costs, and thought it would be cheaper to just put a 25 in there... then got offered a RB25de out of a r32 for $500... then the RB25-30 work started :P
Here are the Parts iv got/ordered so far.
CP Pistons/Rings
Spool Rods/ ARP Rod bolts
Stainless Steel Valves
Ross Balancer
N1 Oil Pump
Geniun Nissan Headgasket (alot of people are refering back to these for there builds)
Tomie Valve Springs
Head has been preped, ported a fraction.
Tomie Oil Resprictors
Oil Collar
Im getting it balanced from the Balancer right to the Clutch.
Chambers will be CC'd.
Using ACL Race bearings as soon as i know what sizes i need.
i also have a microtech LTX12 with ignitors etc to run it all.
i dont make alot of money so i just been saving and buying the next parts il be needing in the build process, hence why i havnt looked into Fuel Set-up yet or Cam Gears/shafts.
the block goes to the machinests in a day or 2.
any extra info or questions will be greatly appreiciated, whats with this water gallery that doesnt get fully blocked or something?
Cheers
CJ
ps, il add more later :) thanks for reading
https://www.sau.com.au/forums/topic/220157-cjs-engine-build/
  • Replies 62
yeh il get pics ASAP.
what would people prefer out of the ORC clutch RMS is selling (twin plate, 709 version) or should i go the Exedy hyper twin from Kudos motorsport? anyone had experience with these clutchs?
Thanks
CJ
As far as I know, the ORC is slightly cheaper than the Exedy Hyper Twin. Im using the Exedy, and no complaints here definitely, but for some reason the pedal is slightly lighter with the ORC twin's ive driven.
That would just be because of a heavier or lighter pressure plate??
Just because the ORC is cheaper, doesnt mean its worse?? (asking a question, not trying to start a argument lol)
CJ
Warning to anyone... if you call jim berry, make sure you got some time to chat! lol. (as everyone told me)
he is making me a custom one now :O after i get the clutch then i can get the engine balanced :O
things move so slow with bigger engine builds :D
CJ
GEt pics i keen to watch this build too, they are so influential. i am re-doing an r32, not engine but damaged rear end i picked it up a few weeks back. anyone keen on a thread? (sorry to hi-jak)
has anyone got pics of a GT42R under the bonnet of a R32 with a 30bottom on it...? (has to be 30 bottom becuase of the height difference)
i can grab a brand new 42R for a good price (veeeery good) and im just wondering if il have enough room between the strut tower, tappet covers and the bonnet.
Cheers
CJ
ps, yeh NYTSKY i ran out of gas for my blow torch :D
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
