Guys i just need something cleared up. In regards to an r33 gts25t series 2, there was the vicious lsd and active lsd.
I have an r33 series 2 1996 model with vicious lsd and i really wana know whats the difference between the two and which is better.
Im always thinking that i should have gotten a later model r33 with active lsd and cant stop thinking if i should trade in or sell my car to get one.
If you guys could tell me the difference, what they do and which is better it will help me out so much and give me time to think about other problems before i goto bed.
Also let me know if its worth selling my car to get one or just keeping mine. Cheers
https://www.sau.com.au/forums/topic/220445-active-lsd-or-vicious-lsd/
eventually your viscous dif is going to give up the ghost it's just a matter of time, go with a mechanical lsd cusco or along with those lines.....factory lsd's arent that great anyway, i tore my factory lsd to shreds the first day at the track.
you couldn't go much later with the R33 series as the R34 series coming was the talked about thing come 1997.
Edited by nizmonut
Im curious as to how the active LSD actually works?
Is it electronically controlled somehow? Or just like a progressive limited slip effect depending on traction available? Or something else?
Yes they are electronically controlled and use a wet multi plate clutch system. Nissan only made a relatively small number of 33's with the A-LSD, I don't think it was only available on the later model 33's though, it was on option on all the models I thought, including S1. I have driven a fairly powerful R33 with A-LSD. It was a bit weird! But it think for most purposes it would be better than a viscous LSD. Certainly not worth selling your car for though!
yeah its not worth the hassle and change of car for it
the a-lsd or vspec rear diff (same thing) has a vspec pump on the right side underneath the car on a shelf.
the reservoir is in the boot on the right hand side and takes auto transmissions fluid.
the system (the same as the vspec diff) watches the abs wheel speed sensors. when it detects one of the wheels is moving rapdily faster than the other, ie: wheel spin
it turns the vspec pump on, which pumps fluid into the diff housing, to make it lock. i ran a bypass into the pump relay and put a switch in my car so i can run the pump non stop.
it doesnt seem to help much and it still sometimes single-spins so its a bit annoying. when it does work correctly the car glides perfectly, like you would expect.
Is it also goes with the R34 as well? does it also take auto transmissions fluid, because I'm using the nissan factory oil. The oil color is Red. Does it make any difference?
the viscous LSD is pretty average. i'd go as far to say it's rubbish. the active LSD is not much better and really a bit of a wank tbh.
your best bet is repalce your viscous diff with a nice, proper mechanical LSD. 32 GTR LSD is pretty cheap second hand, and you can easily replace the clutch packs to make it good as new. or just buy a cusco,kaaz,whatever centre for your current LSD. then enjoy nice, predictable diff behaviour and no more single spinner.
Ok cool, im still a little pissed with myself for not waiting and getting a 40th anniversary r33 but what can you do.
Well if u guys think its not worth the hassel of selling mine for one then im happy to keep mine, it is a skyline after all.
Dont be dude.
Although it would be cool for only because its rare it doesn't offer any substancial advantage. Plus if you want the car to look good you wouldn't want the 40th anniversary kit anyway.
It is not worth the hastle let alone the stress to think about it.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
    • Apologies for the long read My R34 GTT was up for sale at the beginning of spring due to a few repairs creeping up. The strut tops needed replacing, roof and bonnet (hood) painting (yay for 3 stage pearl) and the underside stripped and treated. I sold the car which allowed me to be in a much better place financially. Leading up to the sale I was already thinking about the replacement. In an ideal world it needed to be a good all-rounder. Something I can mess around with, modify, do track days, do the school run, go on long drives etc.  Options included but not limited to... Laurel C35, Evo 8/9, Civic FD2, Impreza Hawkeye, Aristo and even an Audi S4 Avant (I've already got the Mazda 6 wagon). But there was always one car at the top of the list The Toyota Mark ii JZX110 I found an advert on a Facebook group for an example in Japan, from a seller called Jon at Rising Sun Exports. A few messages back and forth and Jon calls me from Yokohama one morning (or afternoon in his case). He briefly explained the import process, the costs involved and a repeat of the advert. After much deliberation, the price was agreed and the sale was locked in. I've never imported a vehicle so I jumped into the unknown head first. The money transfer was completed through wise.com (fees apply), very easy to use and the money was with him within a day or two.  The car suspension was raised for the vessel and the car dropped off at the port. It was 7 weeks later when the bill of lading was received and the freight invoice sent to me, followed by the export certificate a couple of days after (both digital copies) In the mean time the port had been in contact. I needed an agent to deal with the NOVA (notification of vehicle arrival) along with the tax/duty invoice, this was £75.00. The port also had a fee of £100, I'm guessing to cover the cost of the 10 day 'free storage' and for moving the car off the boat etc. They need a copy of the vehicle invoice, freight invoice and export certificate to allow the vehicle to pass through customs. The vessel arrived on Tuesday 5th August, the tax/duty invoice was generated and sent over. This is generally tax 20% and duty 10% of the vehicle value. Although the invoice came in at a higher amount than I had calculated. Once HMRC had received the payment the vehicle could be released from customs. I thought once the tax/duty was paid you could collect at any point, that's not the case. Your agent will need to book a collection slot, I requested Thursday 7th which was accepted, with a 9:00am slot allocated. It was a 5:00am start from Norfolk heading to Southampton. We eventually found the compound, upon presenting the bill of lading and some ID they released the car (they drove it out of the compound to the front ready for us to load up). The email from the port stated each slot had a 10 minute window, which seemed abit farfetched but the staff said it's not a strict rule. We were there for approx. 30-40 mins in total. A week prior to collecting I contacted my garage and explained the situation, I was able to get an inspection slot that afternoon. For the registration, DVLA require the car to be insured, for this I used a company called Adrian Flux who can insure the vehicle using the VIN number.
    • Hey guys, looking for these side skirts if anyone can help me out.
