Hi Guys,
I have a bunch of bits from different cars that I am getting rid of.
I wont hold anything, first to turn up with the money gets them.
email me only! I dont get to PM's often enough and you will probably miss out if you pm me.
2 x Goodyear Revspec 255/40/17 Tyres, 1000k's on them tops. Bought to get through rego. $400
2 x R33 GTR Airbox + Snorkel, one from Series 1, one from series 3. $50ea SOLD!
Pair of R33 GTR N1 Front bar slots (brand new), unpainted $50 SOLD!
R33 GTR Bonnet Lip (brand new), unpainted $50
R33 GTR Blow off valve return pipe that runs under/behind the intercooler from valves. $50
R33 GTR Stock Blow off valves and mounting bracket $100
Pair of R33 GTR HKS Dump Pipes, used but good cond. $300 SOLD!
R33 GTR dash mount for 3 x 60mm gauges, nice moulded unit. Hole drilled in one side for wires (otherwise you have to go through the dash). $150 SOLD!
R33 GTR HICAS lock bar (brand new) $100
R33 GTR GReddy Timing Belt (brand new) $100 SOLD!
R33 GTR GReddy radiator pipe (brand new) $100 SOLD!
R33 GTR Front sway bar $50
R33 GTR Rear sway bar $50
R33 Engine Damper Kit (Brand New) $50 SOLD!
R33 GTR Stock fuel pressure regulator $50
R33 Stock tail lights $50 pair
WGNC34 260RS Centre Console $200
R33 Gtst Front Calipers, Rotors and Rebuild Kit $250
Defi BFII set. Includes Control Unit II, Amber Oil Pressure, Oil Temp, Fuel Pressure, all sensors. $600 SOLD!
Field R33 GTR ECU Loom extender (To go between your ECU and Loom so you can safely tap into your ECU wires. Has had 1 or 2 wires used on it only). $100
WGNC34 (And possibly R34) Air Con loom extension (for putting your AC unit in the glove box or somewhere else). $100.
Pivot shift light. Tiny. Used for a little while. $50 SOLD!
PICS UP -> http://picasaweb.google.com/cbiggins/PartsForSale
Christian
https://www.sau.com.au/forums/topic/220645-lots-of-bits-n-pieces-updated-2505/
can i grab pics of the r33 gtr airbox's,is there anything wrong with the airbox's at all, ill take them both but just send me pics 1st and also pics of the hks dump pipes,
cheers tony
cheers tony
Pics coming soon. Airboxes are fine, were just replaced with pods.
complete rear assembly incl wheel studs?
Um.. Nope, just front calipers, rotors and rebuild kit... like it says.
Christian
Thread updated with new parts.
Emails received will reply to them first (before the PM's because I asked for emails in the first post).
Pics are taken, will upload them shortly.
there is no pics of the airbox, 1st dibs for both r33 gtr airbox
Yeah just realised.. Will get some.
and are they genuine hks dump pipes,
As far as I am aware, they are.
Christian
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
