Hi Guys,
I have a bunch of bits from different cars that I am getting rid of.
I wont hold anything, first to turn up with the money gets them.
email me only! I dont get to PM's often enough and you will probably miss out if you pm me.
2 x Goodyear Revspec 255/40/17 Tyres, 1000k's on them tops. Bought to get through rego. $400
2 x R33 GTR Airbox + Snorkel, one from Series 1, one from series 3. $50ea SOLD!
Pair of R33 GTR N1 Front bar slots (brand new), unpainted $50 SOLD!
R33 GTR Bonnet Lip (brand new), unpainted $50
R33 GTR Blow off valve return pipe that runs under/behind the intercooler from valves. $50
R33 GTR Stock Blow off valves and mounting bracket $100
Pair of R33 GTR HKS Dump Pipes, used but good cond. $300 SOLD!
R33 GTR dash mount for 3 x 60mm gauges, nice moulded unit. Hole drilled in one side for wires (otherwise you have to go through the dash). $150 SOLD!
R33 GTR HICAS lock bar (brand new) $100
R33 GTR GReddy Timing Belt (brand new) $100 SOLD!
R33 GTR GReddy radiator pipe (brand new) $100 SOLD!
R33 GTR Front sway bar $50
R33 GTR Rear sway bar $50
R33 Engine Damper Kit (Brand New) $50 SOLD!
R33 GTR Stock fuel pressure regulator $50
R33 Stock tail lights $50 pair
WGNC34 260RS Centre Console $200
R33 Gtst Front Calipers, Rotors and Rebuild Kit $250
Defi BFII set. Includes Control Unit II, Amber Oil Pressure, Oil Temp, Fuel Pressure, all sensors. $600 SOLD!
Field R33 GTR ECU Loom extender (To go between your ECU and Loom so you can safely tap into your ECU wires. Has had 1 or 2 wires used on it only). $100
WGNC34 (And possibly R34) Air Con loom extension (for putting your AC unit in the glove box or somewhere else). $100.
Pivot shift light. Tiny. Used for a little while. $50 SOLD!
PICS UP -> http://picasaweb.google.com/cbiggins/PartsForSale
Christian
https://www.sau.com.au/forums/topic/220645-lots-of-bits-n-pieces-updated-2505/
can i grab pics of the r33 gtr airbox's,is there anything wrong with the airbox's at all, ill take them both but just send me pics 1st and also pics of the hks dump pipes,
cheers tony
cheers tony
Pics coming soon. Airboxes are fine, were just replaced with pods.
complete rear assembly incl wheel studs?
Um.. Nope, just front calipers, rotors and rebuild kit... like it says.
Christian
Thread updated with new parts.
Emails received will reply to them first (before the PM's because I asked for emails in the first post).
Pics are taken, will upload them shortly.
there is no pics of the airbox, 1st dibs for both r33 gtr airbox
Yeah just realised.. Will get some.
and are they genuine hks dump pipes,
As far as I am aware, they are.
Christian
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
