Go a VH41DE, superior motor, except the 0.4 displacement... the blocks are the same so you can "stroke" it back to 4.5 using the VH45 inners.
If you do get a VH45, for the love of god don't get the USDM version, its a bucket of shit compared to JDM.
R32 would be better choice as it would give better weight distibution than the rb, would leave you with more room to work on the bitch to :(
But the VH45 is about the same weight as an SR20DET if you include the turbo running gear, so the weight itself doesn't change just where it sits.
Oh yeah, good luck with the bonnet :D
http://forums.nicoclub.com/zeroforum?id=193 is your new friend.
I dunno how hard it is to find a RHD VH45, you will have issues with a few things with the LHD afaik, not really worth it
You can use VH45 pistons and crankshaft in the VH41 to bring it to 4.5L
VH engines are all alloy so nice and light, very over engineered engines. You will probably have to go for custom pistons if you want to put anymore than 6psi boost in it but I think the VQ30DET pistons may be a good swap but unconfirmed I believe
Other than that you would just need custom engine mounts, adapter plate for gearbox (VG, RB, W57, R154 all solid choices), custom driveshaft, custom exhaust manifold and there will be a few other bits and pieces that you may need but nothing too major
People have done twin turbo VH45 into S13 so it's definitely do-able
i'm lookin at puttin a infinity v8 into a r32 or a s13
im buildin a drift car..
is this goin to be hard to do???????
you'll want some decent revs for drift. probably best to rebuild it also.
hard... yes
yea i would like to put one in a r32.
i may twin turbo it or supercharge it. i dunno yet.
thnx for all ur help ppl
wouldn't be my pick of motor for drifting.
  • 1 month later...
hard... yes
You don't need revs for drifting!
If you needed all these "revs" why would the Holden V8 boys be able to compete so well, considering they only rev to 5500RPM...
An engine that produces torque, with a well matched gearbox and diff is what you need.
Think about it, the V8s frying tyres in second gear at 5500RPM odd, are spinning the rears at 130KM/h...
Stock skyline, with a stock gearbox/diff is revving at 7000RPM and only spinning the tyres at 100km/h, match the skyline motor to a V8 gearbox/diff, and what happens, it dies in the ass in 2nd, because all of a sudden, at peak revs, it's attempting to spin the wheels at 165km/h... Affectively attempting to use 3rd gear! But the Skyline (And most Jap cars for that fact) are setup to produce power by the way of revs, not torque.
  • 10 months later...
i've been looking into vh45 converion into a 180sx, the biggest problem i can see is with the exhaust manifolds. the engine being DOHC makes the heads wide and the fact it's 90 degree v8 mean that modifying the chassis os needed to get to the exhaust manifold to fit.
by the way if anyones got info on what the clearances are and if there is enough room for block a hugging exhaust as iam very interested in this as i am very keen in this sort converion. as my 180 will end up with either a VQ30DET or VH45 and if all else fails RB26
by the way according to my engineer the maximum na engine you can put in an S13 is just over 5L and 4L for a turbo. so theres no sortage of choice.
Edited by farch
There is alot of misinformation in this thread already, so I wouldn't be listening too much to what has been said...
It's probably best to head to the NICO forums VH section -> http://forums.nicoclub.com/zeroforum?id=193
It's the bible :devil:
  • 1 year later...
R32 would be better choice as it would give better weight distibution than the rb, would leave you with more room to work on the bitch to :laugh:
Hate to dig up old threads like this, but this has shown up prominently on several google searches I've made, and I just wanted to try and clarify on this so the wrong information isn't spread around =P
Now I'm not a VH45 or JDM VH41 expert, but I have done a ton of research into VH45's for several swap I would like to complete (one of which happens to be into an older skyline, has to be 25 years or older to import to the states, and the VH45 would be a legal engine for a swap =D).
The USDM VH45DE is hardly a bucket of shit compared the JDM version. Now the comparison of a USDM VH41DE to a JDM VH41DE, the description would be very accurate. The only thing the JDM VH41 has over the USDM VH45 is the addition of a duplex timing chain, so the heads are a little bit better, but not by a whole lot of difference. Now granted down under, the availability of the VH41 should warrant the simple building of the VH41 using the rotating assembly of the VH45.
The USDM VH41DE is a fairly poor engine however compared to both the VH45DE and the JDM VH41. The USDM model did not have a crankshaft girdle, poor flowing heads, poor exhaust manifold design, and is generally much more poorly designed engine compared to the other two engines.
Again, I apologize greatly for being a grave digger, and it is certainly not something I do often =P I just wanted to say something as this thread has shown up in several of my google searches and I figured it might be worth noting that this information is not exactly correct!
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
