hey all
just bought my rb30e on the weekend and am almost certain its a series two block however there are a few little things that are warrying me. i have attached some photos so those in the now can hopefully put my mind at ease..
http://i13.photobucket.com/albums/a272/danp_87/side1.jpg
as you can see in this photo it has 2 of the 3 holes you would think it should have
http://i13.photobucket.com/albums/a272/danp_87/front.gif
and in this photo it appears to have the flat area above the water pump for the second tensioner location.
i havent pulled too much of it yet cos if it is the wrong motor it can go back in the quokka next week.
also on a totally unrelted thing. the 26 head has the same stud pattern as the 30 block just a thicker stud yeh??
thanks for all the help
dan
https://www.sau.com.au/forums/topic/221130-rb30e/
i cant see and oil drain
looks like a series one to me
every n/a block that i've seen that has the provisions for the turbo oil and coolant feed didnt have the oil drain
i wouldnt bet my left nut on it, but i would say its more than likely a series 2
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3903256
yeah its a series one, from memory they had a bung in the side of the sump dont quote me on it,
however it isnt hard to get it put in , the flat round surface at the bottom of the block below where the word nissan is is where you can drill and tap a hole for a 3/4 inch fitting,
while your at it you could have a T fitting put in there so you can have a drain back for a catch can in the future...just thinking ahead.
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3904036
ok im in doubt now, it may be a series one. can you get a better pic of where the oil drain is (if you know) or just a better pic of that same side of the block
^oil return is in the block, its that black area just to the bottom left of the '67S'. for the thread starter, this is what i wanted the pic of, does it have a big square in the midle of it like for a ratchet to fit into?
Edited by VB-
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3904540
thats why i am in some doubt. it has two out of the three holes and yes its missing the oil drain hole. however above the water pump it does have the flat section to bolt the tensioner to that a series 1 does not. that is the part i am more concerned about. drilling and tapping the oil drain hole isnt so much of an issue. its having the area for the tensioner to sit on that i am more concerned about
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3905352
I didn't think that the s1 and s2 were any different above the water pump.
ps. definately series one engine............
I have a s2 in the shed and it has the oil drain in the block ready to go.
its mentioned alot in the major sticky. thats why i was/am concerned.
but i looked at the pdf and did some quick measurements and will have a spot for the tensioner so have started to pull her apart. now awaiting available 26 head.
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3907989
Rb30 e series one and series two.
the only difference i have ever seen(ive owned 10 vl commodores 4 skylines and a patrol) is the drain back for the turbo as described above.
the fact that they are 3 litre blocks mean they ALL HAVE THE FLAT SURFACE ABOVE THE WATERPUMP!.
the water feed and return lines actually travell around the back of the block from the intake side of the engine
similar to that of the rb20det engines
the ports for these are located near the rear heater hose as it exits the block and also the rear of the thermostat housing on the series two or from the block on the series one.
https://www.sau.com.au/forums/topic/221130-rb30e/#findComment-3909709
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
