It says..
"The Nissan GT-R (R35) is avaliable in 6 colors: Metal Silver, Pearl White, Red, Metallic Gray, Black and Titanium Gray. The standard interior color is black, with either black or gray seats. The Black Edition features black seats with red trim."
I think i'll make mine black. According to Tamiya Body colour TS-14 - Super Black is available.
Reading the manual at the moment and trying to decipher how to put it all together. I'm scared i'll do something wrong and stuff it up.
Also gotta order in the paints. So I guess this will take a while to be finished. >.<
Still It's awesome! :ermm:
https://www.sau.com.au/forums/topic/221475-my-new-r35-gtr/#findComment-3905114
haha good work. I gotta get mine from the post office tomorrow... damn EMS!
So much to do Paint, cut etc... to make it perfect etc ahhhhh not enough hrs in the day/week :D
Post pics of yours when your done! I dun wanna rush mine. hehe
dude :) where can i get one and how much ??
I got mine from amazon.jp was bout $60 delivered. (They dont ship to Aus though)
https://www.sau.com.au/forums/topic/221475-my-new-r35-gtr/#findComment-3905418
:down:
I'll build it later yaaaaaaaaaay.
Bought it last week when it came out sent to a friend in Japan and next day delivery arrived today! w00t
Still haven't got around to builing my R33 GT-R model yet... I'm way behind aren't I?
Cheers
https://www.sau.com.au/forums/topic/221475-my-new-r35-gtr/#findComment-3909844
nice, im getting mine very soon. recently, ive bought the R32 GTR, R33 GTR V Spec, R34 GTR Z Tune, so im gonna build them all when i have time, spray them all the same colour and put it into a display case :thumbsup:
https://www.sau.com.au/forums/topic/221475-my-new-r35-gtr/#findComment-3912907
It's good how the engine is back in again.
I remember when building my R34 GTR there was no engine and some ppl went to the effort of buy the R32 GTR just to take the engine out of that and put it into the R34.
When I get mine I gonna put a V-Spec theme to it.
https://www.sau.com.au/forums/topic/221475-my-new-r35-gtr/#findComment-3913375
Nice; I brought two of these back from Japan when I was over there recently... they're like half the price being charged on Amazon (well at least when I was there for the release date). Bought it from Kids Land (or Super Kids Land) in Osaka.
Did you get the Optional Parts Set? Metal Stickers?
https://www.sau.com.au/forums/topic/221475-my-new-r35-gtr/#findComment-3913501
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
