i was wondering if anyone could tell me how can i minimise this. only happens when im climbing hills at low revs.
alsogoing in for a dyno soon i was wondering is there a big difference between using z32 AFM compared to standard, is it just easier to tune using z32 or
do you get more power from it?
https://www.sau.com.au/forums/topic/221665-turbo-chuffing/
when you say chuffing? do you mean compressor surge? turbo may be too small for the motor. if you have an electronic boost controller, you may be able to bring the boost on later.
as for AFM's, its tuning resolution, air goes through the AFM, and voltage increases with more air going through, problem with the stock one is it reaches max voltage with not alot of air going through it, so when you start moving more air (with a GT30) the ECU wont know because the AFM tops out too early. clear as mud?
https://www.sau.com.au/forums/topic/221665-turbo-chuffing/#findComment-3908353
i had compressor surge with a highflow turbo i had, and it would only surge when coming underload (* going up hills, just comin onto boost)
i found out that the wheels (wheels were from an isuzu truck) that were in the turbo were way too big for it, and was pushing air back through the afm, or something to that effect.
i have a gt30r, and only issue i had with it was idle cause the air coming from it was affecting afm, so the afm was just moved further away from the turbo and is now fine.
https://www.sau.com.au/forums/topic/221665-turbo-chuffing/#findComment-3908633
i think the hks cast low mount manifolds with balance pipe would eliminate it
Balance pipe for a GTR, no balance pipe for a Gtst.
I opted for the 100mm intake with the reversion flutes for my GT3076 aka Gt30r, just in case, to be sure, to be sure [and I have the Hks cast low mount and hi temp coated + extrude honed]. I have nil problems with it, but I am running with Tomei 256/8.5's so it will be just a bit different to std there as well.
You'll need a Z32 with the Gt30r, std will not give enough.
https://www.sau.com.au/forums/topic/221665-turbo-chuffing/#findComment-3909060
lol a GT30R frame being too small for the motor, what a load of rubbish. It has nothing to do with that at all.
R33747 - When you say you don’t have a Z32 on there now, what is the state of the tune?
Fact you don’t have a Z32 makes me think your running a half-done setup as a GT30 is going to give you 270rwkw+…
A stocker AFM wont even come close
Now, the below is assuming you've setup the car and tuned it correctly etc, which I don’t think you have.
The GT30R is most likely the 600hp variant most likely...
They have a compressor wheel that’s classed as oversize... so at low RPM its going to surge, mine did just a little around 2000rpm.
Not a lot you can do unless you wanna start playing around with things.
The easiest way is to get the smaller 500hp wheel in the front, fixes all the problems and the car will be more responsive and virtually make the same peak power.
https://www.sau.com.au/forums/topic/221665-turbo-chuffing/#findComment-3910941
i had Z32 AFM on the car when i had the power fc but when i got an EPA i put the stock ecu back in but the car wouldnt run properly with the Z32. i was just wondering if i could get away with it ( running stock AFM ) because its a hassle changing it. Also what kind of boost would you consider as safe when going for a dyno tune. Ive blown 1 motor and i dont wat to did it again.. I was thinking around 1 Bar. What are peoples thoughts thanks or experiences?
https://www.sau.com.au/forums/topic/221665-turbo-chuffing/#findComment-3915351
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
