Here's the story - The car is a series 2 R33. It hasn't been driven for over 6 months now (apart from in and out of the drive way), however i usually start it and let it run once a week. Last time i started it, it ran fine for a couple of minutes then a tapping noise started to come from the engine. It sounds to be coming from the back of the engine and will get faster as the revs increase. I'm thinking (hoping) it's just the lifters, however i'm worried that it could be piston slapping or something... Any help will be much appreciated.
https://www.sau.com.au/forums/topic/221911-tapping-noise-in-rb25/
does the car still have good power?? i rekon its noisy lifters try putting some fresh oil in it see how you go
I haven't driven the car since the noise started, however the last time i drove it (over 6 months ago) it was still making good power. I plan to try changing the oil soon, if that gets rid of the noise does that mean it's definitely the lifters? Is it even possible to spin a bearing under idle? The noise came on suddenly under idle without previously being driven.
ok mate well just put some fresh oil in it let it run the noise should stop for you, there is no why you can spin a bearing at idle i have heard louder lifters then that before after rebuilds so dont be to worried
thats not a good noise.... sounds a lot like one of the pistons is slapping the wall....... very similar to how mine sounded before we pulled the motor apart and found a lot of bad :<
you need to get this checked out by someone good asap.. fingers crossed for you bud, hope its just lifters.
mate ive heard dat same sound b4 on a rb25det neo that was bought from a reputable workshop. everyone said lifters, so i went to get the shims checked. All were within spec, so wasnt lifters. motor than got pulled apart. bearing were all fine. even compressions test came back fine lol.
And it was the EXACTTTTT noise, coming from the EXACT place. motor was stil making the same power, and i drove it for 5000kms (until the workshop replaced the motor for me) and it didnt get any worst or damage anything.
I had exactly the same problem except it was a little different when i started the car it would go tick tick tick for a few moments then after a bit it would stop but when i was driving i could hear it when the windows where down when i was driving,anyway about a week ago i did an oil change with some motul 4100 turbolight oil and its seemed to have fixed the problem.....the oil is expensive but give it a try it fixed my problem it may fix yours
Edited by benkoau
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
