  • Replies 41
has this car actually run a 9 second pass yet or is he just claiming it because of the power it makes????
ive never seen or heard of this car running other then on a dyno
ohh n im not tryin to bag his car out or anything like that im just curious
Edited by UWISSH!
no...went to the track and ran 12.4 and 12.2 and then finally ran a respectable time of 10.6
Im still the only RH9 car Croydon racing has ever produced (well i built the car, and they did the engine and tuning)
Id really like to have a drive :D
it runs a hollinger seqential and ran slicks to achieve the 10.6, so even if it did run a 9 it still would not be classified RH9 as you have to run on radials.
I prefer to run the numbers before i even entertain the thought of talking up the times...but to each their own i suppose.
Edited by DiRTgarage
would like to see some specs and pic on it...
ill try and list what i know
N1 block
JUN 2.7ltr stroker crank
JUN conrods
JUN pistons
JUN oil pump
JUN 288 deg 11.35mm lift camshafts
JUN titanium retainers
JUN valve springs
JUN and ARP engine bolts (mains head and cam cap studs)
JUN radiator and header tank system
ACL race seies engine bearings
Race ported head
Nitto 1mm oversize valves
Nitto valve guides
Preformance metalcraft 9 ltr sump
TRUST 1.5mm DRAG head gasket
TRUST T88-38GK
TRUST manifold
TRUST external gate
TRUST B-pipe
TRUST 4 inch race exhaust
TRUST 160mm DRAG intercooler
OS Giken harmonic balancer
OS Giken quad plate clutch
OS Giken front and rear diffs
Hollinger sequential 6 speed gearbox
MoTeC M800 ecu
MoTeC CDI
Blitz ID-III boost controller
NOS Nitrous system (unknown quantity of gas used)
Performance metalcraft catch can system
thats just off the top of my head...ill add anything else that comes to mind.
its basically the same long engine as ours without the 2.7ltr crank (ours is STD stroke)
didnt it have twin 3040 turbs on it when it did 1000+hp at the treads???
Funny as hell, i have the same internal mods except it is a trust 2.7 kit and 280 cams in/ex with tilton triple and cusco diffs oh and 3037s twins...
havent seen the car for a while its gone in to hiding...
thought he tried to sell it, funnily enough my 34R is MNPII as well, and no i dont want to be the same... hahhaha
Edited by Dr R
yeh i didnt think that it had run the time, just goes to show that just because you have the power doesnt mean that you will run fast times
what was the story with the runs??? couldnt get the power down? bad launches? bad driver?
I also thought it had twin 3540's and an Apexi twin entry 150mm cooler.
The car definitely has all the gear to run the times very easily...it's just a matter of getting it down the track. At Compak Attak it was the driver's first attempt at racing the car and it was done (erroneously) using full slicks. A 10.6 with 145+MPH TS means that the car has the potential to run well into the 9's.
yeah...it then made 1100hp with the T88-38GK
it may have been John's first time at the track with THIS car...but he's got more runs under his belt than most (previously ran a R32 GTR into the mid 10's as well)
i see the massive brembos have been ditched, possibly to accomodate a smaller wheel for the track?
that photo is over 2 years old...Dario's ute is in the background and its been back on the road for over 18 months
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
