yeah the pic I posted above shows the maltec braided clutch line, I got mine from UAS who have them in stock. couple of reasons for this car:
* it removes that ridiculous clutch damper system and replaces it with a direct line
* increased clearance to the fuel rail when motor is going in and out because the line comes out at 90o and goes straight down due to the banjo fitting
* removes the short factory line which I think is suspect after 18 years.
If you are running the sump extention, then you cannot run the sump baffle, and it would be pointless anyway. The sump extention comes with it's own round baffle, which is a cylinder with holes in it, which reaches down to the bottom of the extention. It welds on to the standard sump trays. It also comes with and extended pickup. The sump baffle kit would sit above the sump extention with the oil below it, making it pointless and it would foul on the baffle that comes with the sump extention kit.
You cannot run the TRUST one....but who mentioned TRUST?....not me...not Andrew...i thought he just meant extending the sump. I had an extended sump which i sold to a customer in the ACT which was extended below the Tomei baffle and had an extended pick-up...worked very well.
Edited by DiRTgarage
Well i was thinking of modifiying the sump around the tomei baffle style. so i could have a bit of an extension and use the trap doors tomei have given me, or maybe i can sell the baffle and go the hi octane one..
possibly do the rb sump similar to the wing style like the aftermarket sr20 ones
Yes it is possible to still run the Tomei baffle with a sump extension.
Why would you want a 6 inch blond when there are so many nicer 6 foot ones?
as for the 6' blond, your right a 6' foot size 6-8 anything would be ok also! haha
For simplicity id go the Hi Octane one...sell the Tomei baffle kit to someone with a streeter.The sump i had was already modified in Japan complete with baffle kit and had a box the same as the internal diameter of the tomei kit that extended down about 3 inches below the baffle from memory. It works well but the Performance Metalcraft/Hi Octane item is a better option and the one i went with. It will hold more oil too.
The clutch pedal in my white gtr was abit hit n miss with the factory clutch line, fitted a maltec braided line, removed that extension bit that runs beside the gearbox, fitted a new slave, went to wsid and the clutch felt soooo much more solid that on the second run my flywheel parted company :D
Yahoo, just got home and i have
And
Just waiting on Arp parts and i will be ready to build!
yahooooooo!
pistons were a bit of a mess, not sure if i like mahle's packing too well there a few tiny nicks hopefully they wont be of any problem.
hahah half your luck.....there are now 4 gtrs without motors in marks front yard. and 2 motors ready to go on stands, one ready to go on its subframe, and one ready to clean and assemble.
its like a fcuking wrecking yard.
btw brad I spoke to mark, drop by on the weekend, we can organise that bending....
And
yahooooooo!
Nice looking rods! Shame they'll be hidden in a block!
Wierd I was just mentioning that really nice n light intercooler on my olg gtr Duncan.... new owner has just posted it for sale, in case your interested;
http://www.skylinesaustralia.com/forums/Ar...er-t236454.html
And
yahooooooo!
I've been running my Pauter rods now for 5 years and 2 engine failures/rebuilds. Now partnered with a HKS stroker crank and shortened HKS coated pistons. They are almost indestructable.
haha thanks Ben I saw that thread....but the price is more than the rest of this car :) we're on this path for now, if we do ever give up I can't image anything except a chinese cooler going on :)
haha thanks Ben I saw that thread....but the price is more than the rest of this car :P we're on this path for now, if we do ever give up I can't image anything except a chinese cooler going on :D
I have/had a chinese cooler and cant fault it.
Finally got my dry sump belts today which was the only thing stopping mine from being finished.
Then onto the next one.
what are u guys doing with the g sensor thats usually under the console? can u move it or wont it work correctly anymore? im thinking of throwing mine under the dash area to get it out the way (obviously mount it level and straight as it is now), do u think this would cause any issues?
Don't think it's a good idea to move it. I'm sure it will still work, but it will work best when located in the most central part of the wheelbase. I suspect it should actually be moved backwards a bit.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
