It's kinda a rolling twelve months. We'll get there eventually. I'm now living in Melbourne so the car is down with me in the workshop. Between here and April it won't get touched as I've got to get the other car ready for Targa, but after that I'm pretty keen to get moving on it. Lot's of weekends and late nights ahead of me.
haha stable....that's exactly what i need to store all the cars :rofl:
lol michael as if you don't have 2 projects on the go yourself :P when is that race car going to be back on the track btw, was a shame not to see it at the national sprints at morgan park last month
damo, honestly can't remember. but they are a cheap forged one, originally bronze but we had Craved powercoat them white. they look excellent, hopefully they will be strong enough.....
BTW this bloody car better be seconds quicker than the production car. otherwise I'll burn the f**ker to the ground.
That is true mate. But im always doing or trying to do something crazy and overly time consuming.
Good news the race car is finally running. Needs to get tuned to suit E85 now and then its time to actually get back on the track. Stupid cars, you fix one problem, then another problem thats never been an issue pops up. Fingers crossed there are no more! The rings appear to be sealing perfectly now since I assembled this motor dry. No oil vapours out the exhaust and nothing out of the dry sump tank breather. :D Just as it should be!
Dont burn it to the ground if thats the case...just swing it my way! :) :) :)
  • 1 year later...
  • 2 months later...
hey good perserverance!
what happened is that the car was about 70% complete, when Mark had to move to melbourne for work. I had no space for the car so it moved with him, and I don't think he has got back into it.
I still think it would make a great track car, and when I need a second project again and the garage is ready, I may bring it back up here and finish it off. It really owes us bugger all and should be reasonably quick and fun.
It will never go to a $uperlap though, that event has come way too far and I'm not interested in spending $200k for 10 laps and finishing in 70th place....there are lots better places for club style competitions
  • 4 months later...
haha I'm sure it's not the only build thread on long term hold.
It is still down in melbourne gathering dust, and I would still like to finish it one day. First I have to do the ute, get the March aback, get my race card running, and then buy Brad's truck and go and recover this car from Melbourne. So, I guess not this year :)
  • 7 months later...
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
