It uses individual inputs for the channels. You can either sniff off factory sensors such as water temp, or add new sensors. Usually you sniff water temp, add Oil Temp, and Pressure sensors, (add / sniff air temp depending on car), add fuel pressure and boost sensors.
The unit lets you put in the calibration points, its easy Voltage versus value. I have the calibration tables for a lot of sensors and if there is one I don't have I can do the table if you send me the sensor then add it to the available list.
It does not do knock as per PFC.
It will have the Lap Timing feature in it with the new ones that are coming now. That is what I am adding over the Christmas break. The guys at STZ Auto have one of my data loggers and will also have the new EM PRO II in their race car for testing etc. On a side note they are also testing my tyre pyro unit (3 sensors for tyre temps across tyre surface) that interfaces into my logger. To use the Lap Timer a GPS signal will be required.
Some of the features I have added that I think are "nice" are the advanced oil pressure alarm that allows you to put in 4 pressure points against RPM points. That way you dont have to wait until you have a minimum oil pressure (such as 10psi) while the engine is still at 7000rpm (for example, set that point up at 60psi). The other one is the fuel pressure alarm that is linked with boost, you put in the rising regulator scale factor and the fuel pressure is tracked against the air pressure in the engine. Again getting a much more accurate alarm.
So you think racers look at knock level on a game boy or oil temp, water temp and pressures etc.
Of course they do. Not many cars out there can be driven flat knacker lap after lap and not many guys out there have a pit wall full of people looking at the live data to get on the blower and tell them to look at problems. The reason why logger shave info on them with common alarm lights it to let the pilot know when temps are getting too high from too many revs, following the car in front too closely. Diff or gearbox temps getting too high. Oil pressure dropping...it may only happen on the straights when they have a fleeting moment to look...but I am sure they are looking at data otherwise why wodl they spend all that money on the dashes
There is a serial port connection on the unit. It is used to connect to a Laptop to set up the unit, download calibration data etc. You can set all the alarms etc from menu screens as well. I usually put in the calibration tables for you if I know the car and sensors being used. The serial connection can also be used to connect to the datalogger for logging the EM PRO II information. It will now also be used to connect to a GPS for the lap timing option.
The EM PRO II unit is $499, comes with two stage shift light and warning light and alarm buzzer. Also includes looms and external buttons.
I will have to get current 2012 pricing on all the sensors etc. I can get Oil Pressure Sensor, Oil Temp Sensor, Oil Sensor Spacer Plate, Intake Temp Sensor, Water Temp Sensor (usually just sniff factory though), Fuel Pressure Sensor, Boost Sensor.
If you have an aftermarket ECU (such as my GTR runs a HALTECH) you can copy the calibration tables from it into the EM PRO II and sniff off their sensors). I have tried to make the sensor interface as flexible as possible.
I am loving the oil pressure versus RPM alarm, and also the Boost versus fuel pressure.
However, wouldn't it be better to have maybe 10 available points to tune, so you can tune very 1,000RPM/10PSI of oil pressure?
When an alarm is triggered? does the alarm automatically go off when the fault has gone or does the user have to acknowledge the alarm?
Yes I can get aftermarket sensors and the ones I supply I have the calibration tables for ready to go. They are all quality sensors, Bosch, VDO etc.
On the number of points for Oil Press vers RPM, I understand what you mean by having points every 1000rpm but in practice this would probably become troublesome. Tuning the 4 points can take a couple of tweaks as on the track the oil pressure does drop slightly as the oil gets hotter. We tuned the 4 on the dyno, then had to adjust them again at the track with fine tuning.
On Alarm Acknowledgement, when an alarm goes off the screen shows that alarm "LOW OIL PRESSURE", if more than one alarm goes off they are in the priority order you assign to them. With up to 4 on the screen.
If you have assigned the Alarm Light, Buzzer or both to an alarm it will go off. You have two choices for clearing it:
1. Set the auto clear mode, this will clear the alarm once it has gone automatically. With this mode there is a user settable minimum hold time, so you dont get an alarm flicker (such as oil surge) and then when you look at the screen nothing is there. Set the hold to 5 or 10 sec and you will always have the chance to glance at the screen and see what the alarm was.
2. Set the alarms to only clear when you press the acknowledge button. Then they will hold until you clear them.
  • 3 months later...
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
