I know some people dont like the Ignition Bling but this will change your mind about our DVDs
I don't mind some of the bling but I'd love to see a special on Australian Skylines with a challenge between cars on all 3 majors (Circuit/Drag/Dyno). Who has the best overall car?
doesnt need to be done...Berry/Neuman GTR is the best overall car...no doubt
That the hi octane 32?
yep sure is...if you threw two more catergories in like Street and Show i think we would be in with a fair chance.
mark and russels car runs blistering circuit times, runs 10.2 at the strip and makes over 400KW at the tyres so its a great 'allrounder'
Interesting, but Street and Show are not exactly definable so this leads to disputes. Registered could be another entry point, is Mark and Russels car a road registered weapon?
it will be available online in 10 days and at stores in 3 weeks. wont be sold at Newsagents due to a lisencing deal with a diributer
Where in West Australia will this be available as the only ignitions we get now are the ones bundled with magazines :cheers:
Ignition hasn't been bundled with magazines for quite a while and won't be from now on.
In West Australia it is the only way to get Ignition DVD well thats how i have got the last 10 or so and i am up to number 30.
they are NOT for sale any other way over here!!
i was getting them through a newsagent independently at first then they could not get them any more except being bundled with hot4's
so my question still stands
Where the hell in Western Australia will i be able to get this issue from ??
Edited by gazza750
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
