Engine bay looks immaculate, love the engine cover, partition, brace... awesome! :D u post on SDU quite a bit yeah?? i think u see u on there quite a bit... a whitish avatar? GTR logo, white background?? or am i thinking of someone else?
oh yeah, and did u have trouble with ur car or something, like it kinda died but came back to life?? :)
anyways, beautiful engine bay/car....
cheers.
Yeah that's me dude, just look up top 10 posters and you'll find me!
Actually I was the number one poster on this board for a while, then things got busy and I didn't post for a year or so...
Anyway the car has been off the road for a year or so basically. Fuel pump died causing it to run lean and detonate, then they rebuilt it and didn't do a good job so near the end of that drag run that's posted above a big end knock occured.
Got them to rebuild it a 2nd time and was still having problems!
3 front cylinders are lean, rear 3 are rich but very noisey, cambelt too tight, piping etc very dirty, camshaft scratched as they didn't put everything back together properly and just found out yesterday that my new turbo's have gone because of all the problems!
It pays to pay proffesionals, I went against my better judgement and let a friend point out a garage that seemed really good. Guess they weren't!
Anyway it is now with Nissan and they said a new engine would be the best way to go...
Will keep you updated :D
Basically the place that done my 2 rebuilds didn't get it right either time!
3 front cylinders are leaning out, rear 3 are running rich but making noises. Cambelt was done up too tight, the caps under the camshafts were put back in the wrong order, the clips that hold the camshaft down were put around the wrong way, they left gunge in the piping which went through the turbo's causing them to give up...
So it's start again time!
Nah it won't be ready for Dyno day bro, to be honest it's not looking like it will be ready for Autosalon either!
If it were 100% I'd be looking at the 280kw mark at the wheels, hopefully more than that...
Sorry I haven't been in touch Troy, trust me when I say they don't pay enough. Im just lucky I still live at home and don't have to pay much rent, sacrifice for wanting to own the car I have lol :)
Hows your baby going anyway dude???
Im hopeing the people that stuffed up will pay out for it, will be over 10k worth so I don't think it's going to simple. Im getting evidence together incase it has to go to court!
Originally posted by Anguss R33
Hey bootiful, long time no... email! :)
What happened to my daily emails huh? Seems like you just couldn't be bothered anymore :)  :shake:  hehehe.
Hope things are all good, hows ya beast anyway???
will be in touch soon Anguss...got lots to tell ya :D
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
