ahaha
2004 BA xr6t, silhoette,leather,premo sound,elec sunroof,turbosmart bov,advanti 19s, rapid v3.0,k&n,dba slotted, centre muffler removed,tripod,siemans deka 60lb,valve springs,actuator,walbro pump,king spirng ssl/sl combo,whiteline 27mm swaybar, s.a race auto 2800 high stall,PWR trans cooler and my cat went missing.........327rwkw..........Bruce Heinrich Tuning
elec sunroof, turbosmart bov,advanti 19s, rapid v3.0,k&n,dba slotted, centre muffler removed
turbosmart bov, advanti 19s
advanti 19s
definitely in a place to be giving others shit about their wheels...
hahaha love it.
ahaha
advanti 19s
lol nice sliding at last drift prac btw stew didnt get the chance to come say hello
my wheels dont poke that much, and fitment is what jap cars run!?
unlike the +45 x7 wheels falcons and holdens run.
also sticking with the japanese theme (domokun) in the front window.
oh but you drive ford, excuse me for being so far from imports on a import forum.
wow soft spot?
yeh we dont know how to fitment or slide in our oh so crud barges lol.....still dont get the rim pokage tho, is /was there a point to it (performance) and i come here for the lol's mainly at the p platers good fun ......keeps me entertained
+1
what have you done?
now runs a custom mac strut front end, basically not 1 thing resembles the old setup, or any other setup in any other car for that matter haha, but there's a few niggling issues at big lock (60+ degrees) which are slowly being sorted.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
