It was old stock and the guy wanted $350 for it. But it had a little scratch on it and I was going to leave it. Then he said it was going to be cut up in 2 weeks if it wasn't gone. So I offered a $100 not to cut it up and got to take it home.
I know its not legal but I wont be using it that much. Its more of a test fit for now.
  • 3 weeks later...
  • 3 weeks later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
