Yank Tries To Turn Cpv35 Into A R35 Gt-r.
F*CK ME SWINGING! That is a gorgeous 4door 34 your have DRFTT!
Wish I could I say the same bout the cpv35..
Jash at C-Red built the R34 from a Non Turbo Auto and changed everything to my knowledge including the diff's, it has a new home now up North I think, CPV has long gone.
Have a look at the Laurel he built.......
Actually thats a kit from Webber sports out of Japan. They make a very similar front for the 350Z. So it's not really a yank trying to turn his car into a GTR. It's a yank putting on a bodykit.
Not my taste, but if you read the effort he's put into it it's a very very good job.
I honestly think it looks alright. Nice looking kit and if it happens to have similar styling to the gtr then why are y'all bagging it saying it looks ugly when you all love the gtr? Sounds like jealousy :P
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
