  • Replies 40
Hi Rekin,
Yes AutoTechnique is their co-business and it does look they are a Holden/Ford shop but they have informed me that they are moving into the Japanese car market.
This is the first year we are using them for the Dyno. They have a pretty good set-up with Plasma and Sofas for the Dyno etc.
Even if you dont end up Dyno'ing your car, come down for a watch
cya
Bran
I think it will be great to come down.
I printed the flyer off today.
I'll probley come down and spectate, take some photos, get some BBQ and drinks ;)
The Dyno day at RE Customs was kick ass! Big turn out.
For sure everyone is welcome.
I am not sure how big of a turnout it will be this year as I seemed to of chosen a date just after a few Dyno Days have just finished :D
Sure man
I try and spread the word and get afew ppl down to spectate and dyno if not already done at the SAU Meet Dyno Day at RE Customs.
Sure man
Thanks buddy. Appreciate it!
I might come down and put the car on the rollers.
is there likely to be many big numbers cars there?
Well a few years back some of the GT-R guys came down like Snowy, Frank and Ferni they had some great numbers but this year Im not sure.
This year there is an BMW M5 coming, M3,
An Audi RS4 is still tentative.
A C63 AMG Merc is also Tentative.
If the Evo X is released before the 5th then there would be an Evo X coming.
This year there seems to be a lot of clashes with other things .. a lot the regulars are not coming :ninja:
So ... Hard to say guys but I hope so :P
wouldn't mind seeing how the power of my car is on another dyno with new plugs and cleaned throtal body
Its a good way to see how the car is running.
i always see monaro's parked outside the place, so im guessing they will also be attending hehe
Yah they probably won't be. But we are deciding on a car to be a Mystery Car for "Guess the Kws". Raffle
The WRX club sprint at Calder has now been canceled. Might pop down Brandon ;)
Yah if you are in the area pop down.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
