On a side note, if anyone is interested in a group buy for Royal Purple products in Victoria, I've started a thread in the vic section. If there is enough interest I'll organise it, but I'd rather keep it vic only, as it'd be much easier to keep track of, and other states seem to be able to find RP products easily enough.
How much per quart and min qty required? any more details?
cogs, depends on your budget. But something like Castrol Magnatec or Mobil Synth S would do the job.
CCCP, Personally I would say take it back and buy the EDGE 5W30 instead. The 10W60 is pretty damn thick for a stock motor on the street.
I thought its only for modern 4Cyl engines... anyway i ent back and got 5W30! Thanks :laugh:
LOL yes thats what the bottle says but they are just marketing it towards the ricers. Most new cars, 4 cyl or V8s run 5W30s/10W30s these days! In the USA the oil of choice is now the 5W20.
I am currently running Shell Helix 5w40... should I see much fuel economy/better response now that this new oil will be thinner?
You may or may not feel it. Some claim there is no difference. Others comment that a 40wt feels sluggish compared to a 30wt, especially for those who live in cold climates. Different people with different cars... so no guarantees but its definitely not a bad thing! Let us know how it goes...
what can thick oil do to your car?
It will cause too much startup wear, once heated up to operating temp there's actually not much difference between a 30wt to a 50wt...
For example let take a look at Mobil 1 0w30 when compare to Mobil 1 15w50EP.
M1 0w30
cSt@40'c = 63.1
cSt@100'c = 11.0
M1 15w50EP
cSt@40'c = 138
cSt@100'c = 18
So at 40'c ambient summer temp, during startup the 0w30 will flow 118% (74.9cSt thinner) faster then the 15w50 but at operating temp the 0w30 oil is only about 7cSt thinner then the 15w50.
Edited by Trex101
There's a major factor people forget with oils and thats environment temperature. After speaking to a guy from motul the 10w-40 is meant to be only good if the temperature is 5-35 degrees and the 15W-50 is for use in 15-50 degrees. So for people in the hotter areas of australia where an average summer day is usually above 35 degrees the 15W-50 would be better. I know people have said that the 10w-60 is not good for street use, and that may be true as the oil doesn't get as hot (compared to track use), but for those in the hotter areas, the oil temp does get up above what it normally would and to save using one oil for winter and one for summer the 10w-60 does cater for all seasons.
It used to be true ambient temperature does plays a big part in old air cool engine but modern water cool engine oil temp just doesn't fluctuate that much be it in summer or winter condition. If you have an accurate after market oil temp gauge, you will find that the temp is pretty constant be it in 0'c or 50'c ambient.
Motul 300v 10w40
cSt@40'c = 89.5
cSt@100'c = 14
VI = 161
Motul 300v 15w50
cSt@40'c = 128.1
cSt@100'c = 17.8
VI = 154
Actual oil temp directly affect the final viscosity, so depends on your avg oil temp and target viscosity needed. You can accurately choose your choice viscosity.
Use the calculator to calculate the Vis at difference oil temp
Viscosity Calculator
Hey Guys
I been using Elf 10w-50 in the R32 gts-t for the past 2 oil changes now and it has been running smooth.
bout $50-$60 a bottle i think, of 5 ltrs from autobarn, not 100% sure though.
No real issues, warms up nicely, does the job, engine runs nice, doesnt overheat
This oil was used on the recomendation of bel garage.
just my 2c
maybe he needs to move into the 20th century...cars are water cooled now LOL oil temp doesn't fluctuate nearly as much anymore under normal driving conditions, i.e. street.
also that has been covered already..so it hasnt been forgotten
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yep, its been down for a while, as I understand it it will be back soon.
    • Yeah I also looked at Plazmaman, but, it ended up alot  cheaper getting black ones through EFI when you also added in the delivery cost
