Mobil 1 is good, although, i think it's an oil that needs more frequent changes than others...
RB's are "lifty" fullstop. Mobil 1 did quiet mine down a bit, Royal Purple made them quieter again... i would probably stay away from "lifter free" sounds horrible.
Good oil, fairly often. Just stick with that :)
hey Gareth :P, i got it from harold, $11.99 per quart, and you need about 6, $71 - i was just putting it into a more friendly measurement, litres instead of quarts. But it's still around $70 for an oil change
6? Do you have an oil cooler or something? 6 * 0.945 (is that was a quart is?) that would be 5.67 litres.
Anyway, you probably did tell me and I have a terrible memory :laugh:
Yes, I don't like the quarts measurement, its confusing.
hm, i change my oil at 5000kms or less. So non frequent changing is not the problem.
Maybe i try the mobile 1 0w-40w. Without lifter free. Might need to look for an alternative oil tho. 0w-40w fully syn around 90 for 5 litres!
Anyway i inform you guys how it goes. =)
changed oil today from quaker state 20-50w to redline 20-50w went for a drive an heat it up pretty good then on idle started to hear a clicking noise(the kind u hear when u switch off an your exh is coolin down) seemed to be commin from the exh side rocker cover. Car has done 120000km an never heard this before. Any suggestions as to what this might be? By the way its not a constant noise it comes an goes.
yea.. agreed..!
I got told before to use 10/60, buy a guy at repco before...
He said if i used anything lower, my engine would be destroyed............................................................
I smiled and walked off. Lol!
  • 3 weeks later...
Hey guys, Just some feedback on this thread. Took the advice of the blokes here and the mobile one gold 0-30 worked great. Unfortunatly Its too good and I felt the engine was moving too freely and it was to thin.
Now have moved onto motul 5-40 I think xcess 8100 and its pretty good stuff. BTW oil change at 10,000km on the skyline with mobil gold came out slightly deep gold so its good for awhile id say (no oil cooler and yes I gave it a nice run)
Hope that helps some people, I just felt the 0 weight was too thin and would give too much unwanted engine wear.
yeah, Castrol Syntec is their true synthetic oils... and surprise surprise, you can't buy it off the shelf here... well, not that i know about.
I would stick with the german 0w30 though.... i've heard a lot of reports that the American stuff is actually Group III, but Castrol decided they wouldn't tell anyone... :)
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
