Everything he sells are Group IV, IV/V or V
I'm using Royal Purple 5w30, but will switch to Amsoil next. Apparently a slightly better oil (Group IV/V blend) but little price difference.
Castrol Edge would market their oil as synthetic, as would the Shell one (Helix?), Havoline something-a-rather, but they're all Group III.
So you've been chatting to Harold too? :3some:
I was previously using German Castrol 0w30 in an RB26, on a track day (only 4-5 hot laps at a time!) and a cold day, oil temperature just got to 90 degrees celsius at Sandown. EDIT: This is group IV or V, not to be confused with Australian Castrol (cannot confirm if its group III or IV or ...)
Royal Purple is apparently, a group IV / II blend or is it V + II (?) anyway bobistheoilguy (forums) have a big debate about if its good or not, Amsoil was not recommended as that great either, but often recommended over Mobil1 and Royal Purple.
However, the only thing those guys seem to consider "good" is Redline oil (good for track, pretty average for street apparently) and other very high end oils.
Personally I'm using Amsoil 10w40 next change because I want something with a higher viscosity due to possibly doing a spring/summer track day :thumbsup:
It's seems there's lots of movement in regards to what oil is what group... Some of the Mobil 1's are apparently not Group IV or higher - Castrol EDGE is apparently Group IV but Edge Sport is Group III - and now there is talk that some of the very new Group III's are competition for the old Group IV's... damn confusing if you ask me.
bobistheoilguy members would be hard masters that's for sure. I'd love to run Redline all the time but it's really pushing in terms of $$ and considering you should change after every track day... it could get very pricey.
Waiting for my account to be verified at bitog so i can dig around :)
hey i have an 81 mgc210 skyline with 168 000 km on the clock what oil would u reccomend for an engine of this age iv been told if i use too thin an oil it will leak out the seals i no its a simple question but id really like an answer im changing the oil and filter in a few days.
Maybe phone Penrite, they make a pretty good product thats not off the wall when it comes to $ and at least you'll have an idea what type- Dino, syn, semi, etc and viscosity you will need, even if you don't buy Penrite.
My guess in Penrite would be, mineral , HPR 10 or HPR 15 , or mineral 10x40 or 15x50 in any decent brand , in but I'm no expert.
  • 3 weeks later...
I just found this
e-monitor
I will be giving this a go after my next oil change and post up some results.
I was running 300v but just can't justify it with the all the daily commuting I do. I have just changed to Nulon 10-40 Fast flowing stuff, will see how it goes in 5000km.
Snap.
After endless "best oil" searching and no discernable conclusion looking likely , ever, I went with a Valvolene 10-30 semi syn which behaved like flushing oil when hot according to my oil pressure gauge so I rissoled it after 20ks and having read every oil bottle label in Autobarn that seemed remotely relevant I to decided on the Nulon 10-40 fast flow fullsyn and so far it's looking good, nice hot /cold oil pressures and the engine sounds comfortable.
Not at all technical but seems as good a yard stick as many I've read.
:P
Edited by BASHO
I just found this
e-monitor
okay, long story short I won 3 5L bottles of mobil 1 0w40
question I have is would I be safe to put it in my car, which says to use 5w30 on the oil cap. I've just been using motul 300v 5w30 so far
my car has a VQ37HR motor essentially same as vq35hr and done about 20,000k's so far
I always ran Amsoil and Amsoil filters in the USA.
The oil doesn't break down like the other synthetics..
What is the interest in bringing in Amsoil products here in Sydney?
PM me if you would purchase it if it was available here in NSW!
performancelub.com sells that oil, take a look his shipping rates are pretty good...
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
