How many of you guys get oil analysis done to see which oils are working better and how well they are lasting?
Would be good to see instead of a lot of the anecdotal evidence that I read on here, not saying the oils are bad or people are wrong just that it'd be interesting.
I would like to do this next oil change, but I hardly do any km so its not worth doing yet :ermm:
I cannot recall what the cheap website was that was $30 or similar for the UOA.
Yep, definitely depends on the tolerances. Run in with something thick like a 20w50. After that, switch to something thin, it's always better to start thin and go from there...if she's burning oil then step up the viscosity a bit. The person who built the engine would be best to advise this though, of you are concerned about it.
S 6000 for a staff discounted $45? Must be on clearance cause they've stopped making it :ermm:
Nah Galois I haven't heard anything about the replacement, although you can get Syn-X 10w40 (30% syn) now, which is their most popular oil (therefore won't be going anywhere unless GW does).
Birds ,or anyone else willing to give some advice.
I will import a 2001 M35 Stagea with 115,000 on the clock .
I have no idea of the service or driving history from Japan,
but my guess is there must have been a lot of stop start driving. it wont have been driven for 6 months when I get it.
How should l I approach the oil change and what initial oil should I put in it.
In Brisbane I was expecting to run a 10w -40w Royal Purple but don't want to be dumping
an expensive synthetic oil if the advice is to clean the engine out over a few oil changes.
I will also eventually install an oil by pass filter .
Edited by samuri
Hi samuri...I would do a major service on the vehicle as soon as it lands in Australia, particularly if you don't know the service history. Timing belt, water pump etc.
But yeah, change the oil as soon as you can for a mineral 15w40 / semi 10w40 and run that for a thousand km or so...then chuck in the Royal Purple. You don't need to flush a vehicle as extensively as Galois did unless the engine is really dirty like his was.
Hey,
Just would like to know, the best Oil for my R33 GTR, and where abouts I could grab a bottle or two from (Melbourne, Northern Suburbs)
Thanks heaps in advanced.
Forgot to mention, its a fresh import currently sitting at 70,xxx and sorta in the same boat as Samuri
Edited by kinggtr
for both you guys (samuri and kinggtr) i woulg just grab the sougi s6000
its a good oil up there with the royal purple etc but so much cheaper and australian owned (i think)
put one lot in (~$60, just call gulf western and ask for a distributer in your area, autobarn and supercheap will be able to get it for you but you will pay rrp + freight)
leave it in there and check it every week, it'l start going black pretty quick, but its not breaking down, just dissolving the sludge in your motor (good oils go black quicker cos they are doing something, a cheap oil will look about the same colour after 5000kms)
once its fairly dark, change it
you'll get 2 changes out of the sougi to what you will out of the royal purple
Just went and got some Motul 8100 as recomended by most members here, and a Drift oil filter over the ryco(no k&N in stock) Autobahn. Noticed its 5-40 and not the 10-40 that i was looking for in an oil. Will this be fine for street use? The current nissan oils only about 2500km old so I thought it would be a good idea to change it now while its still half ok and not too dirty for the 8100. Just taking extra precautions as this is my first oil change for this car :P
It'll be fine mate, i liked 8100 when I used it, noticably better than the nulon I had before it (though that was semi-synth, despite what the packet says).
5w and 10w refer to the cold viscosity of the oil, the higher the number, the thicker the oil. The important thing to remember is that from start up they're both converging in viscosity to become a w40, so they're getting closer and closer. Another thing is companies don't publish 7w or 9w, they round off, so 5 and 10 can be pretty damn close.
The lighter an oil is, the quicker it moves through the pump and filter to protect the lifters and valves. The thicker the oil is, the longer it takes to get there but once it's there it provides better protection. It's a trade off, like all things are. And it doesn't really matter, because 5w and 10w are so close anyways.
Enjoy the feeling of a happy engine :)
thanks for that pipster11
I have a day off 2moro, and planning on doing a full service, on the car, oils coolant diffs, gearbox ect. Just kinda stuck on where i could buy some motor oil and gearbox oil ect
thanks heaps all
If u want it tomorrow:
Go to autobarn and buy what castrol recommends on the castrol australia website. Split a bottle of nulon g90 between them, apparently it helps out.
See if your local sougi s6000 sealer has any in stock, or else buy some 8100 xcess, 300v or royal purple from your local autobarn/supercheap/repco/autopro blah blah.
People on here seem to like the nulon pre-mixed long life coolant (llc) but replacement means you need to drain the block, radiator and heater heat exchanger.
Hope it helps.
You sir, are a champ.
Will swing past autobarn and see how i go, and doing the job isnt really the problem, its mainly just finding the oils and using the right ones.
Can you please give me a few good names for the gearbox and the diffs? And if i could buy them from supercheap or auto b?
The brief lubes thread in the transmission section mentions the penrite limslip 90 and the syn 75w85
http://www.skylinesaustralia.com/forums/Tr....html&st=40
I mentioned the nulon g90 above, it's been replaced (as far as I could tell) by g70. I've got ome vmx-m and g70 to put in my box but the f%$#ing grub screws won't undo, going to buy one of those little gas torches from autobarn, a trolley jack and some car stands and hopefully put in its place haha
*galois is then spotted with the r34 on a lorry heading to a mechanic*
Anyways, kidding aside, the castrol ones are cheaper and I'm gonna replace them regularly (20000km) for a while to give it a bit of a flush with fresh oil as I don't think it's been taken care of by the prev owner.
The thing with oils is they'll all work decently otherwise the company would go out of business with the publicity of a failed oil. So a bit of trial and error is okay.
haha naa easy tiger, with the blo torch
ill see how i go tommorow, thanks again man
Best price on a group 5 oil is Gulf Western Sougi 6000, it can be found for $60 for 5L
Where can I find it this cheap :) Autobarn had a single bottle scratched up all over the bottom,had dust on it. looked at least 100 years old. the guy said it was a mistake order. $89...So i got the $79 8100 instead.
Good luck with it, sounds like it's gonna be a big day. Just buying one of those lighter torch things, everyone seems to suggest applying some gentle heat. I hope it works, the gearbox is sounding really unhealthy.
Call gulf western to find your nearest distributor. I bought 4x5L bottles for $256, which is $64 a bottle including gst. My guy delivered it himself to where I work as it was on his way somewhere, now that's service. Give them a call from the number on their website, buy some or find a distributor for next time so save some dosh.
If you buy from autobarn/repco/whatever it becomes a LOT more expensive as they mark it up again. Sougi s6000 should be compared with 300v, grade V, so better than grade IV oils but not really necessary for a street car. 8100 is a good grade IV oil, it has heaps of fans on here.
i paid $68 from the distributer here in tas
they have a guy who comes down from ulverstone (east of devonport) and drives to launceston a couple of times a week
he just met me where convenient
you could also call up a distributer, find out the price, go to supercheap and get them to price match it!
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
