hey guys just wondering what oil weight you would recommend for a fully built rb25 its oil change time and i was gonna go with redline 15-40w i have been using castrol edge titanium 15w60 but someone suggested this isnt a good weight for goldcoast during summer? i know this has probably been covered in the previous 152 pages but i dont have time to trawl and ive done a few searches but not really answered my question. so i thought i would get some opinions
anyways cheers for any replies
Ask the engine builder.
They put it together and know the tolerances.
iv always used the Castrol edge titanium 10w40 in W.A. summers and seemed to do the trick just fine.
Not sure about your built engine tolerances tho so the recommendation to check with the builder is a good one.
Nonetheless, as the motor was recommended stock to run 7.5W30, I think 10w40 is a good number for these older motors and warmer conditions. Also a fully syn is far beyond the requirements the guidelines note.
I've always used Castrol Edge Titanium 10w60 and it's on special now at Repco for $59 for who ever else uses it.
I snapped up a box while I had the chance.
Do you track with that oil too? What sort of temps are you getting at track if you do?
I hate this process haha lol, so boring waiting for all the oil to drain out lol, would it hurt to put some compressed air through the oil cap to push the oil down a little.
Edited by MrRx7s3
Well I've put the Penrite Racing 10 10w-40, I'm impressed, engine is as smooth if not smoother than the Royal Purple, oil pressure is better than with the Royal Purple, overall so far with a short drive I'm happy :-D.
It wouldn't hurt, it would just go out your intake....
Drink beer while it drains. Perfect excuse.
  • 3 weeks later...
Just put in Shell Helix Ultra 5w-40. Best oil I've used for the RB25DET.
Smoother quieter idle, very smooth running and revving.
Had Penrite HPR5 5w-40 in there and that was not bad but it seems better with the Shell.
Before that had Valvoline Synpower 5w-40 which made the engine run very smoothly but the Shell seems slightly better.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
