SAU BANNER
131 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I wonder if anything will change?
Okay, so you think the R35 is a bad choice and only because it isnt a skyline?
Cmon theres got to be more reason than that./
Brand association isnt that strong these days for the internet and i highly doubt readers will be turned away because an R35 heads up the banner.
Im all for it.
And i think it would look hot. At the very least, a banner that fades in and out - one that depicts different cars and scenes would be sweet.
  • Replies 98
Posted Images
Like that car sales banner that you see at the top now and then.it fades from 1 pic to the next
OR i also like that pic which has the r32,r33,r34 & r35 all parked next to each other.
What about R30's and r31's? their all skylines and should all be presented.
But nah,i dont think it should be just a R35.
I would like to see the R32 R33 and R34 on it!
haha... as they are the most famous of the skylines right? :thumbsup:
R32 is the Godzilla... the R33, is the most popular and the R34 gets alot of media attention.
+1!!
But if the r35 was in that montage it would be ok too cause I think it looks awesome! And it is an r35 so it is related to the r32, r33 & r34 despite not carrying the "skyline" name.
Yeah actually i agree. Not JUST the R35, but all the cars from the KPCG110 thru to R35
+ 1 from mee to. That photo should be one of many though..
I still think a slide show banner would be the way to go.
WTF has happened? It looks sooo cheap now and its 50% advertising?
Is this the way sau is going? so sad :)
Well donate to the forums then you tightass and stop complaining.
If every member gave $10 a year, there would be no need for banner ad's and so on.
Traders only bring in a small amount compared to the massive running costs of this forum.
Even the SAU Clubs donate, i know SAU-Vic does and will be doing so again shortly :)
People that complain, but aren't willing to help, shit me.
lol good point. these people think running a website is free business.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
