  • Replies 181
  • 4 weeks later...
after setting good pace at the time attack the poor little lotus won't be doing any more racing :P
RIP
good to see john and Peter both came out of this with no serious injury, hopefully john will be back after his broken leg is mended
Ok, here's a few from Targa Tas this year with myself and PHAT MR30 calling the notes :P
Gets grotty with all the corner cutting;
The Cethana lookout
** Thanks to Perfect Prints for the pics**
The footage from that camera is where??
:D
Oh sorry guys. lol... shoulda thought!
PROLOGUE -
KAYENA -
ROSSARDEN -
LIENA -
There's another 35 odd stages to upload once I work out how to trim them up. :D
I don't know how to trim video up so some you'll need to FF about 2 minutes or so. Timmy had to turn the camera on, wind the window up, get everthing sorted etc, theres always plenty to do :D
Oh, and forgive my prologue perfomance, gearbox mount.
Savman's got a bunch on there too.
Edited by Marlin
great pics Ben! i know i know i shouldnt be looking ....no time!!
very shocked & a real shame to here about the lotus and peter, i hope they are okay and the car can be repaired!
i'll bet it wasnt peter's fault.
cheers russ
A car before had dumped oil on the track, and the Lotus and Ferrari where the first ones on the scene of the accident, before the flaggies had a chance to get the oil flag out.
