Sau And Wrx Club Day At Sandown Video - Fuel Cut Tv Show
Hi All,
If you'd like to see some footage of the day feel free to check it out:
http://www.youtube.com/watch?v=sZ1k9VCGQn0
http://www.youtube.com/watch?v=nkWXc3znGFA
The segment is made up of two parts so make sure you check out both of them. If you want to check it out in High Quality, simply slect "watch in high quality" under the view count on the bottom right of the video.
All feedback is appreciated.
Thanks guys.
Fuel Cut TV Show
Great piece of work there.
just a bit of feedback, early on around 15-19 sec mark where it moves up, then cuts and keeps going... it flicks to the next cars a bit too fast (R34/Black, R33/White).
Great work with the grey scale and the fast motion parts through the pits etc, looked sensational!
Haha great work mate...the footage is great!
...although being taken by a liberty is nothing to be proud of :)
haha I saw that, you messed up the exit of the last corner and he flew past inside you (was a good move too)! but you got him on both straights so that's all that matters:D
nice footage
nice footage
Yes nick, thats a true sign of talent, overtaking people on the straights only to be passed around a corner. :):)
yeah sarcasm doesn't play well over the net and I didn't want to be too harsh! maybe I should have gone with the :P instead of the :O
what... isn't HP all that matters!?................................. ;)
that's why my car is with benno at the moment, to make up for my lack of talent (no sarcasm intended there lol)
wow nice work like the video loved the editing top notch job,
Drools at all the cars at the event wish my engines was good as all of times but im just starting with my car not finnished with it yet but hope to get it as close as good as all of those. ^^ i am so envy at all of those car's
haha Jarrod and Nick. reminds me..
you did team 180 proud.. nothing but class.
good editing anyway. good interveiws. superlap will like the free plug :P
if this makes it to channel 31 will it be the same or is there going to be more talking?
also, i think if you have footage of people having a spin or shooting off track it give the impression of being on the limit. i love to see a good lose. hell, i love having them as long as there is no wall love.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
