Hi guys,
I am a happy and proud owner of a S2 v35 coupe in NZ. And I guess I am also one of those lucky ones in terms of keys for the car as mine came with 2 set of key and 1 valet key.
The car also has the immobiliser sticker on the window and my understanding is the NZ compliance does not have any rules with regards to the standard of the immobiliser.
I am keen to try out to ensure that the immobiliser is working or not. There is always a red LED light right next to the driver's side air condition vent that is blinking. I saw in this thread that to try to check if the immobiliser is working or not, one just need to take a copied key to try starting the engine with the original keys far away from the car because of the transponder chip in the original keys.
I haven't really made a copy of my original key. But does the valet key has a transponder chip in it as well? Can i use the valet key to test?
Advice on this is most appreciated!
Cheers!
Picked up my V35 Sedan this week and it came with just one remote and one key, and like others I didn't get the keycode with the car.
From reading this thread it appears the BCM code in the kick panel can be used to get the pin for a new key. I looked in there (see piccy) and it didn't look exactly like the others photos on this post. Is my BCM code from the piccy 3B071??
Mine is a 12/2005 manufactured V35 GT350 Sedan (4 door).
Any help appreciated!
Mike Mac
keys.pdf
  • 5 weeks later...
Does anyone know how this transponder in the key works?
My wife's V35 sedan has 1 key so I had an idea. Why not get a key from a wrecker, get it reprogrammed and pair it with a recut key. To test the theory I got a flat key cut and tried it in the V35 and of course it did not work. The engine spun but did not start. I put the original key beside the flat key but still no good. I stuck the original key thru the hole in the end of the flat key so it was metal to metal and hit the starter but still no go.
So how the hell does this transponder work?
I made a post about this some time back.
I got 2 old keys from a wreck, bought 2 blanks from england took the internals out and put them in the new blanks.
Had them cut and reprogramed all done working perfect $180
Chris
Tried to find your post but couldn't. Were the keys you got from a wreck V35 keys? Do you have a URL for where to get the blanks?
Bob
Chris
Bob
Hi Bob
I got the blanks off Ebay UK
http://cgi.ebay.com.au/Nissan-X-Trail-3-Bu...=item2eafa4d37d
they are really trustworthy and you get the keys in 5 to 7 days
and heres the post I made on the cheap keys
http://www.skylinesaustralia.com/forums/Ch...on-t320201.html
Hi Bob
Thanks Chris, will see how I go.
For those who live in QLD i have a friend that can copy any key.
Just got two keys cut and programmed for my V35. $185e or cheaper if more than 1 or group of people get together and he will come and do them all.
They are non nissan keys btw.
Dont need BCM code, just a current key and the car. If you are after details please PM me.
Cheers
  • 3 weeks later...
:(:) Well, picked up my new remote and blank keys from the Nissan Daler today (Unley Nissan in Adelaide) (ouch!!) but they couldn't code the new keys. Apparently their software could not get into the system (I gave them the pin code for the ECU ok). They said they thought it would be the same as the 350z software but apparently not - mine is a 12/2005 build V35 Sedan 350GT with the 3 button remote and the transponder key with no buttons (see piccy). When they booted up the software it apparently wanted to "reset steering lock" and they didn't want to reset the whole system in case it was permanently immobilised.
Has anyone else had a problem with resetting the 3 button remote that unlocks the doors and with this model keys???? If Nissan can't do it here where do I go?
Mike
find a dealer that knows how to change region on a C3 machine. the dealer I use for my parts here in brisbane has no issue with it.
short of that find a autoelec with a launch scan tool. that WILL do it.
Hi all
Well a very happy ending for me!! :P
Went to Main North Nissan here in Adelaide and spoke to Josh (excellent friendly service!!) and they coded the new remote and keys no problem!! Strange thing is, it is the same dealer as the one in Unley that couldn't do it, just a different branch. Just shows you you need to get the right person for the job!!
Anyone, I am safely sitting with spare keys and remote now :rofl:
Thanks all for posts
Mike
  • Like 1
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
