Thanks Dan. You would'nt happen to know if an R34 diff ( non GT-R ) is the same as R33 GTS-t in fitment ?
What I want to do is put a lower ratio diff in my car to get more out of the revs ( especially on the Freeway ).
The GTT - Auto - RC40 - 4.0 : 1 diff might be just what I need.
Really need to find out my diff ratio now :)
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-3982164
  • 2 months later...
what centre can i use to put it in a r34 25GT ?
atm mines only a single spinner so i want a lsd that spins both wheels.
would a r33 gtst diff centre fit?
what about a S14 or S15 one?
can i just shim up the standard centre i have now ?
Edited by dori32
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-4142842
Some info:
GTT auto diff is 4.089:1, manual is 4.111:1. The difference is unnoticeable.
I put the diff centre from an R33 into my GTT and it bolted in perfect. We looked at doing the housing but it didn't look like it would fit, although I think the one we had was a non ABS R33 so perhaps that was the reason.
I bolted an R32 GTR diff, housing and all into my GTT. The traction control stopped working but I didn't care. The ABS still works.
Scott, if you're still looking, I can ask Dan if he still has my old 4.089 centre lying around. I left it at his place as that's where we did one of the swaps. It single spins when hot but with no turbo this may not matter and would be free. Otherwise, anyone who has put a mechanical centre in an R33 or R34 GTT will have their old worthless centre lying around which you could use.
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-4155703
Some info:
Cheers for the heads up. It's sort of a project on the slow boil atm.
First thing I'm pondering is what sort of speedo error will result if I change from a 4.3 ratio to a 4.0 ?
Who's good with maths ?? :P
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-4157302
For every 1000rpm at 1:1 gearbox ratio, so 3rd gear in an auto or 4th in a manual, with a 4.083 diff (I found the figure, last time was off the top of my head), you do 29.7km/h by my calculations. This is 3370 rpm at 100km/h.
With a 4.3 diff it's 28.1 so 3560 rpm at 100km/h.
So a drop of nearly 200rpm with the different ratio.
I think this is 5.3% out on the speedo so if it shows 105 then it's actually 100 and since it's likely without the diff change to be doing 102-103 when showing 105 already, there's only about 2km/h for you to worry about when Mr Plod looms over the horizon.
*It's early in the morning so I may have stuffed something up but it sounds right.
  • Like 1
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-4157330
  • 2 years later...
hi guys im also interested in changing my NA r34 gt coupe's diff ratio i looked at the firewall plate and it said ive got a RC40.
i looked up and someone said they should have an RC43?
does anyone know where i can get a diff with different ratios to it will be more responsive?
and also any info about shift kits for auto's as well in victoria.
cheers.
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-5909488
cheers.
why are the stock diff ratios so high also?
is it even possible to make them higher?
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-5909569
  • 2 years later...
hey guys reviving this thread, so do all r34 25gt 4 door autos come with a final drive ratio of 4.363 in the diff?
Hard to say. See bottom of page 3 for confusion.
http://www.nismo.co.jp/en/products/competition/lsd/pdf/lsd_price.pdf
You can see 2WD R34 NA autos have both the 4.083 and 4.363 diffs. But if you look really closely you'll see that NA cars with a viscous LSD have the 4.083 ratio and the cars with open diffs came with either.
This table is supposed to be accurate, but in reality, the number of R34 (GTT) helical LSD cars that actually appear to have been made is close to zero, despite being in the table. They exist, that's why they're in the table. On the same basis, there might be very few or almost none of the RB25DE autos with the 4.083 ratio. Or there could be lots. I don't know.
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7245933
  • 4 years later...
Reviving this thread. My GTT was originally auto and was also converted to manual in Japan, it states that I have the RC40 but how I can check to see whether this is still the case. Also if it hasn’t been change previously and still is the RC40 what would be the best option keep it as is or change it for something else.
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7881932
If you don't have a reason to change the ratio then leave it alone until you think of one.  If you are going to double the power you may want to get an LSD but not necessarily change the ratio.
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7881943
Why change from 4.083 to 4.11?  Makes no sense.  You will never tell the difference.
As to the LSD.....The Nismos are broadly considered to be the nicest.  1.5 way for the street.  2 way for hardcore carpark action.  After that, Cusco, etc etc, are all rather similar.  Some have different features (like being able to alter the config from 1 to 1.5 to 2 way).  Some are really harsh to live with but can be moderated a little with different oils.  Have a read on here for mentions.
If I was to replace my helical, I would probably go Nismo.
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7882034
  • 4 weeks later...
Thanks for the info.
The issue I’m having with my r34 gtt sedan that has no major engine mods that was converted to manual in Japan is that I’m losing traction way to easily in 1st and sometimes in 2nd, (powers just not making it to the ground properly). I’m moving to a wider wheel setup so hopefully this reduces the loss of traction a bit but if not I’m thinking the next option is changing/upgrading the diff.
It’s my daily driver so 1.5 way would be where I’d want to go. Would a vspec GTR diff be an option?
As you can probably tell I’m new to this so slowly learning my way around things.
https://www.sau.com.au/forums/topic/226081-r34-diff-ratios/#findComment-7883444
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
