  • Replies 68
Sly33 have you tried pushing anymore than 16.5psi? I thought these turbos would take 18-20psi on an RB25? That said I will be happy with 280rwkw if I can get it:)
yes, in my application it would not hold anymore than that boost. which gets me to thinking that its pretty close to its potential. 280rwkw works out somewhere roughly round 450+/- hp at the fly, seeing as the turbo is rated only at 420ps, that sounds about right.
i can squeeze more boost in the midrange, but as it revs out the boost drops back to 16.5. I havent gone to lengths such as wiring shut the wastegate or anything like that, as ive heard some have done to get to the 300rwkw mark with this turbo. thats gotta be pushing it, and ive been happy with the 280rwkw. The stock honed ex manifold is purely just for experimentation rather than chasing more power!
Ill leave the car as it is until i put a 26 in it, and then sell off the whole running forged rb25/2835pro setup, including literally everything, injectors, tuned power FC etc.. anyone who wants this setup down the track keep mine in mind :woot:
Seem like a real solid turbo for the RB25DET.
Question. You guys running on MT or AT ? Cos I wonder how will the AT box that this turbo.
MT all the way baby :(
weird how it wouldn't hold boost... mine is pretty happy @ 20 for a most of the range... what bc are you using?
remember that running more boost isnt necessarily good, especially if one setup is making more power with less boost.
sydneykid would tell you mine is more efficient hehe :D
that said though i think my above post relating to the turbo simply reaching its airflow potential sounds about right. I had exactly the same deal when trying to push the 2530 (using an e-boost).
now running a blitz spec-r ebc.
Edited by SLY33
had a close look at your car while i was there man.. very nice :)
rob was telling me about your car, sounds really good congratz on that!!
Now i needa get my car going agen :) 3076R .82 and try reach the 300kw mark agen :D
thanx phil!... that setup should see you @ 300 fairly easily i'd imagine...
sly33: true that i'm running a fair whak of boost to get the 265...
but comparing dyno's (to your non built 266 one) i'm getting 170rwkw by the time your's is on 130... who's more efficient now huh :P
Hey Phil car is back on the road mate :)
The run-in tune has been tweaked, but a full tune is still required once i have clocked 1000km.
VERY happy with the result!
rb30det + GT3076R = 304rwkw@16psi with instant response :D
rb30det + GT3076R = 304rwkw@16psi with instant response :)
Thats really impressive already - you will be going for 20psi or so? What is your setup, internally gated or a high mount w/ external? Stock or aftermarket plenum?
Thanks.
Full tune will consist of 20psi, setting the adjustable inlet (modified the std gear and maintained the VVT) and exhaust gears, boost controller (as it is currently working just off the actuator), rev limiter set to 8000rpm, more ignition timing and better tune.
All items stated above are subject to gains gained. ie: if no valuable power/torque is gained from increasing boost to 20psi, i will leave it at a reasonable boost setting. Same goes with the gears, timing, and rev limit.
PM sent.
Cubes: the curve feels alot better than it looks too :D
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
