just been lying at home bored as fark watching rpm. and cameron mcconville was being interviewed saying ford are dropping funding next year, he implied that teams may be dropping ford and turning over to the generals holden. only fpr and another team i forgot are being funded after 2009. mcconville then said 4 years ago holden werent welcoming toyotas idea, but as of this forthcoming news holden are now welcoming toyota who have been interested in joining the league. what car would they use?
would be boss if they could whip out built 2jz's rather than 8's. either way it should be sweet. something to look forward to!
https://www.sau.com.au/forums/topic/226917-ford-to-drop-v8-supercar-funding/
  • Replies 40
Posted Images
yeah its very bad new for tony cochhead. he has built the series on the cosy local duopoly and telling evey other manufacturer to get stuffed. now ford are loosing money and doing the sensible thing. GM are about to go bankrupt in the us but holden are still paying the money - their support will drop within 12-18 months for sure.
toyota have been aus's biggest seller for a couple of years so clearly motorsport is not an essential thing for market success in aus.
tony will go crawling back to any other brands but no-one will come up with the sort of money he wants, and no-one has dinosaur v8s to run anyway.
its breaking my heart....sooner or later you reap what you sow. but i bet cochrane will be happy to wash his hands of the mess and leave aus motorsport in ruins.
QFTT with bold for emphasis.
Yeh Brett is ace!
I know at present that Cockrains is looking for a replacement in the next 24 months or so. He i walkign away from the sport and cant imagine the mess it could be in at that time.
Good thing is we still have some good teams. I mean do you really thing Triple 888, Prodrive and the foreign teams are going to hang around if the rules geta shake up and running a race team is no longer profitable?
Hmmm. Mismanagement may mean our tin top series ends up looking like the ARC :P
Yeh, i can understand that. But he was the journo talking to the Garry Rogers etc. So i suppose its a matter of , was he a journo or a V8 driver towing the line. It turns out he was a V8 driver towing the line :)
I still watch the V8s and really enjoy the racing. But even i am starting to tire of the "show" they are putting on
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
