Im freaking out about all these stories of balancers coming off now!
I got mine off fairly easily the other day. I tried cranking the engine with a 300mm bar resting on the radiator mount, but that didnt work. So then i fit my trolley jack handle over the breaker bar (making a 1 meter long handle), put the car in fourth with the brake on and really leant on it. It came off ok, but i could feel the stretch in the timing belt (i think thats what it was anyway). Just waiting for my ATI balancer to arrive now.
I think ill definately use a bit of loctite in the thread. Maybe the blue semi permanent stuff, rather than the red permanent.
Is there any point in replacing the bolt and washer if the original is undamaged? Theyre only $8.50 from Nissan, but i was wondering if the older (work hardened and stretched) bolt would actually be better than a new one that might stretch or move and maybe loosen as a result. Maybe im becoming over paranoid now.
Shaun.
Edited by Shaun
i have tried to get mine off and had no luck, this must be the hardest bolt ive ever tried to get out, i had a 1 meter breaker bar and was cranking the engine whilst the bar was on the floor, and all it did was lift the car....
im going to try cubes method, 4 gear, handbrake and massive massive 2 metre pole....
I usually use a square galvanised fence post/stake; only just slides over the breaker bar and is fairly easy on the hands as it has a flat surface. Then rock hard/bounce against it and before you know it its off.
I've also used a dewalt 18v rattle gun; removed the std rb20 one that was impossible to get off when the motor was out of the car.
So, when i go to do the bolt up again, am i right in thinking that i should use my 1 meter long handle and just put as much force on the thing as possible. When i say that, i mean put my entire body weight, swing off the bar type of force?
Im just trying to figure out how much torque up to 500Nm is. I mean, is it possible to snap gears in the gearbox, or break a timing belt, or strip the thread on the bolt or crankshaft???
Makes me shudder thinking about it. What do you guys reckon?
Shaun.
Shaun; You'll never break the cam belt as all the cam belt does is spin the cam shafts..
The rubber band feel is the driveline and most likely the IRS rear forcing the arse end down. Which is why I drop it in 4th 1:1 as I'm not keen on placing so much load through the drive line even though it should be able to handle it.
I've placed a hell of a lot of load on mine without breakage; the leverage I've had I had to shorten as it was hitting the bonnet. It should qualify for VFT :O
I've always hit the bolt with a wire brush to clean up the thread and then applied red loctight.
Ok, thanks Cubes.
Thats exactly what i wanted to know. Yeah, when i think about it logically, there's very little load on the cam belt. Feel like an idiot now, but it kinda looks like a rubber band, and thats what it felt like!
Shaun.
Edited by Shaun
Shaun.
Croydon uses a massive torque wrench, and unfortunately i was present when they did my torque bolt. It was a bit 'disturbing' to witness being done up. Teeth gritting stuff.
Childs play... i dunno why ppl do that shit for.. i did mine to 14xnm and ive never ever had any problems with it.. infact, when i had to take it back off again to build it, i couldnt.. had to get it off with the 1" rattle gun @ work..
500nm+ is just stupid and has nothing to do with how much torque ur car makes.. u could put the bolt through a 900nm rattle gun and ur driveline wont feel any of it
So your saying if you applied 900nm to the crank the usual single plate clutch would not slip? Or have I misunderstood. :bunny:
I think the problem is a fair amount have had their balancer come loose and let go. Most likely due to track use?
I know the torque of the bolt has nothing to do with the torque my car produces; i was just trying to put it in perspective.
Shaun.
Shaun.
If Mark Jacobsens GTR which has the most power out of any GTR in this country, that sees a lot of ignition cut rev limit and high revs, cannot shake a bolt loose using the same method as I described, then i dont think you will have anything to worry about.
Just use a moly based lube to get the correct torque when assembled. I wouldn't recommend Loctite or any other anerobic compound.
Edited by DiRTgarage
  • 11 years later...
How about just go off the 440 - 466 Nm as is in the manual ? We use an rb26 starter motor that is cut in half and welded up locked to lock flywheel and a 3/4 inch drive torque wrench, and go to 460Nm. Pretty easy when flywheel is locked properly,
And the right length torque wrench.
yes it is when all other rbs are around 150Nm. You'd be surprised when doing it that its easy to get to say 200Nm, then to get to the 460Nm it was around 1/4 of a turn more. Took notice the last couple of times to confirm this. Hardest part is getting a good quality 3/4 inch drive torque wrench as they are worth heaps.
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
