iam thinking of the same set up on my car,so what your saying is that i need a bigger pump,some rx7 injectors......how much are they? and a remapped chip,should i get one from toshi....how good are his ? or should i just get mine remapped on a dyno? ive heard this setup is good for around 230-240rwkw?
  • Replies 61
I would get yours remapped. every car is different. I dont think getting someone elses tuned computer would be good as each car has its own individual characteristics.
as for the parts: new pump around $300 - $400 regulator $200 - $300. as for injectors i havent really looked around but i think 2nd hand im guessing around $400 for the 6... not too sure
im going to try with stock injectors.
remap really depends, ive heard around $750 is about the usuall going rate.
If u are going to go more than 230rwkw you will have to change injectors i think, i would even consider possibly a bigger turbo than a 2530 - to make it a little easier, but remember the 2530 is very responsive anything bigger and your power range will be alot higher in the rev range.
well im not too sure to be honest, i asked for an 044 but the guy getting it reckons thats over kill he rattled the name of it but i cant remember. something like 58... i dunno its about $300 (and thats with some sort of discount) it supports alot more power than i need and fits in-tank easily.
Have you put yours on the dyno yet?
I just put a bosch 910 in my car. After installing the td06-20g turbo the car with the stock ecu and fuel pump was getting very lean towards the top end of the power curve. The new fuel pump really made a big difference, now the car runs much more richer. So instead of forking out for injectors I'm gonna do the ecu with just a fuel regulator and try and keep the car to around 350-370hp. I'd love to crack 400hp, but if I crack that I think I'm gonna have to crack open the engine and put better internals in. The pump was $220inc gst and fitting was around $125inc gst.
yeah they are very cheap.
I just got the sexy sard regulator. probably a bit wanky, but it has anodized blue fittings and machined look. i got it very cheap tho with the skyline adaptor plate. so it fits straight in too.
Im just wondering whether the car cut out due to an airflow cut or because it sensed the pump couldnt cope...
anyone know if skylines do have fuel cuts? because i was running higher boost with the std turbo.
ECUs that are re-mapped on a bench arent exactly the best way to go. It assumes a lot of things concerning your engine.
It can work and im sure it has worked for ppl out there, but as an absolute minimum i suggest you get your car dyno'd to check A/F ratios once you have your bench written ECU installed. Just to be sure its not way off.
The beauty of getting car tuned on dyno is that the good places (read expensive) monitor fuel rail pressure and flow, injector duty, use forms of knock detection etc etc to be sure that the increase in power isnt going to shorten the life of your pride and joy.
i got my Sard Reg from Envy imports. they had them in stock with all adaptor plates and fittings for standard 8mm hose or threaded fittings for braided line.
very helpful and had what i needed in stock. they even ordered the pump i wanted and i received it that very day.
i hate having to wait :P
Yeah they are actually cheaper. they have the Reg with the skyline adaptor (usually $30 or something) with fittings for $330 total
i was pretty stolked with the price as most other retailers were selling for $340 without adaptor or fittings
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
